Results 1 to 20 of 20
Thread: VT Boot lid holds water
    VT
    Jan 2009
    Default VT Boot lid holds water
    Hi
    When it rains and I go to open the boot of the VT water pours out of the the boot lid when I lift it right up and goes straight onto the inside mat of the boot, it never used to so i am assuming that its not draining or going where it should go. Can anyone give me any ideas on how to fix the problem it must be something simple.
    Megs
    Jun 2005
    you got a spoiler?
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    vs commodore sedan
    Jul 2005
    mine did the same down the bottom of the boot lid is that plastic thing i drilled some holes in it now it never fills up or gets the inside wet
    Thomo's Avatar
    Thomo is offline UNLEASH THE LION WITHIN
    FAMILY VT & HONDA 04 CRF250
    Aug 2005
    Goldcoast
    their is a rubber seal that runs along the top of the garnish if thats not sealing it will leak aswell the 2 square seals that run on each side of the garnish make sure they are there if not you need to seal it with new ones or silicone.
    VT S
    Jan 2009
    hey my boot gets water in it aswell..
    i been told the seals are fine and its something to do with the spoiler, been told to just silicon it up lol.
    VT berlina series2
    Aug 2005
    well mine ****ing does that it shits me to high heaven i don't have a spoiler though,...
    what the fudge do i do to fix it??
    H1GHROLLR's Avatar
    H1GHROLLR is offline CHEMICALLY SUPERCHARGED
    VX CLUBSPORT R8 LS1
    Feb 2009
    ROCKINGHAM,PERTH
    yeah my vx used to do it its the seal on top of the garnish it goes hard in some spots
    sxc_sound's Avatar
    sxc_sound is offline getting Kustom
    VT Series 2 S pak
    May 2008
    Parkdale
    i have a spoiler, and i don't even have the top seal on the garnish, mine doesn't leak a drop , guess im just lucky, or its getting into somewhere real bad that i just can't see and one day will end badly
    PORT3R's Avatar
    PORT3R is offline WTB: 1 money tree
    5L VQ stato
    Dec 2008
    Melbourne, Vic
    According to my dad (whome designed the VT) this is just a design flaw, there is nothing you can really do to stop it
    Quote Originally Posted by stocky View Post
    anyone got any special tricks for removing a screw that doesnt want to turn?
    Quote Originally Posted by Sphinx View Post
    I recommend explosives.
    VTII Acclaim
    May 2009
    Port Macquarie NSW
    hey guys, got exactly the same problem. spare wheel well is full of water and it pi@ses me off everytime i open the boot lid, water pours out every where. What success have you had with drilling holes in the bottom plastic trim? or seal on top of red garnish?
    98 VT Berlina
    Nov 2008
    Western Suburbs, Victoria
    VT97CALAIS's Avatar
    VT97CALAIS is offline VT-Best Holden shape!
    1997 S1 VT Calais /A4
    Mar 2006
    near CRANNY m8
    Yeah mine too rather chronically the water is inside the Calais garnish looks shi-ite too...
    How do i fix it? Get a hair dryer and dry it out and re silicon the top in summer time ? 'No point in doing it now cos its too cold and wet, it wouldnt seal properly...
    MattyC's Avatar
    MattyC is offline Just cruisin bro
    VT Calais 5L
    Jun 2009
    Yeah guys, i'm having this same problem with my VT II S...
    Water seems to pour out of both sides of the boot when i open it.
    VT ll S Pack
    Jun 2009
    yeh i seem to get the same on my VT II S....ive got a custom interior boot cover...and after i wash it or its been raining, water comes out from the left corner of the boot...its really sh*ting me.......when you guys say the garnish..wat exactly is that.....and is it someting i can just fix myself???
    cheers
  15. #15
    D-Man's Avatar
    D-Man is offline All over it...
    99 VT Calais II v6
    Aug 2008
    Melton, Victoria
    cheers
    the boot garnish is the peice of plastic inbetween the rear lights.
    it is the piece that holds the number plate there, sometimes the seals corrode and let water in, mine just had a crack in it and that's why mine was leaking..
    i replaced mine for $60 delivered (from ebay) and ripped off the old one and put on the newer one, no more water anymore..
    it's really easy to replace.. just search google, i found a website that explains what to do..should have kept it..
  16. #16
    VT ll S Pack
    Jun 2009
    thanks heaps dude
    ill see wat i can do so hopefully i jsut got the same issue you did...was it much messin around to put the new one on??
  17. #17
    D-Man's Avatar
    99 VT Calais II v6
    Aug 2008
    Melton, Victoria
    im just trying to find that internet site i had for it.. i will chuck it up when i do...
    replacing it wasnt hard when i had this guide,
    mine had a crack in it. not sure what is wrong with yours without having a look...is there any cracks etc in it?
    found this on a site just then too - RE other explanations of the boot retaining water.
    Boot Lid Water Retention - Some VT's have a nasty habit of collecting water in the rear garnish panel, and when the boot lid is opened, the water empties into the boot area (or on your head). A common cause is the washers that go between the garnish panel and boot lid. These need to be resealed to help prevent water entering into the boot lid.
    Top Deck lamp seal - Part number 92081490
    Deck Lamp Moulding seal/insert kit (with revised upper and lower garnish panel) - Part number 92142403
    Water may also enter the boot area from an aged or defective boot spoiler mounting gasket.
    S Pack Spoiler to Boot lid Gasket – Part number 92144151
    Lumina Spoiler to Boot lid Gasket - Part number 92144153
    SS Pack Spoiler to Boot lid Gasket – Part number 92144150
    Last edited by D-Man; 19-07-2009 at 06:35 PM. Reason: Found this explination too...
  18. #18
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    mine was lecking in where the rubber stop mounts screw into the boot so i just siliconed them up and it stoped
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
  19. #19
    VT ll S Pack
    Jun 2009
    cheers noodles
    that would b awsome if ya get that site if ya could pass it my way
    im sure if i jsut simply have a look at it i would find the proplem, but if not ill have to try a few of those options
  20. #20
    MattyC's Avatar
    VT Calais 5L
    Jun 2009
    AARRRRGGGGGGHHHHHHHHHHH
    today i went to my car with mates and opened the boot to put bags in and WHOOOOOOOOOM water came gushing down out of both sides of boot lid
    now what is going to happen when i get subs!!
    Hmmmmmmm
    ill write down check seals for next service.
    thanks
    Third Ride: 2002 VX SS 5.7L V8
    Second Ride: 1998 VT Calais 5L V8
    First Ride: 1999 VT S Series II
  1. Water in Boot
    By Rodeo058 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-05-2009, 09:11 PM
  2. Water in boot Lid
    By G4orce in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-12-2008, 07:40 PM
  3. Water in VS boot lid.
    By SunCoastSister in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-04-2006, 02:06 PM
  4. Water in Boot Lid
    By U2Bono in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-06-2005, 12:29 AM
  5. VS - Water in boot lid.
    By pod in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-07-2004, 09:48 AM
