Results 1 to 7 of 7
Thread: VX SS Airconditioning
    Woody67 is offline Check1Check1
    Vx ss 5.7L
    Feb 2009
    Default VX SS Airconditioning
    Hi all im a newby so go easy.
    My VX SS airconditioner has recently started to randomly turn off if it is set to the highest setting. i usually turn it to a lower setting and everything is good. anyone elso experience this problem
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    What do you mean by highest setting, temperature or fan speed?
    MY RIDE
    VX Calais & VP Executive.
    Oct 2008
    i've been having the same prob with my VX calais. it tends to happen on hotter days only though?
    VT R8 S2
    Oct 2008
    i have a vt series 2 hsv, and i get this happening to me recently as well! if u listen carefully i can hear a clicking coming from the fuse area, ive checked all fuses and it seems to be alright, so ive also got no idea wat it is!
    commsirac is offline Banned
    vx
    Aug 2007
    Quote Originally Posted by Woody67 View Post
    If you mean the blower fan, it could be that it is tripping the high pressure switch, especially if we are talking about the problem occuring in the severe heat of the last week or so.
    This points to the system being perhaps slightly overcharged or the condensor just not being able to cope with the high heat load, do check that both cooling fans are coming on.
    You can check if it is high pressure by testing for continuity across the high pressure switch, not sure where it is on your vehicle, its in the high pressure line somewhere.
    VXII SS M6 & Leather
    Nov 2003
    Warrnambool
    sorry to invade the thread but this is also a VX SS aircon question (saves a new thread).
    At some point the engine has been out of my car so the aircon has been degassed, and hasnt beed regassed as of yet.
    when the engine is running, the aircon compressor makes a squeeking noise which eventually quietens down when the engine heats up.
    if i spray some WD40 or belt grip on it, it stops the squeek for just a few seconds and then returns.
    also, if i put the aricon on, the thermo fans start up automatically and fail to turn off at any point (even when the car is cold).
    is this all to do with the system having no gass or is there something else not right?
    vs exec series 1 and vt series 2 acclaim
    Jan 2006
    i had a similar thing happening turned out it was a relay in the fuse area can't remember which one and too lazy to go see but have a look and you will find it then either get a new one or go to a wreckers
  1. VE SV6 Airconditioning Noise
    By Lenny66 in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-06-2010, 07:03 PM
  2. Airconditioning shut down
    By mick0960 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-11-2008, 05:13 PM
  3. Airconditioning G
    By gsmrobinson in forum General
    Last Post: 13-12-2006, 11:10 AM
  4. Vt Airconditioning
    By emufriedchicken in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-02-2004, 09:42 PM
  5. Vr-vs Airconditioning
    By gsmrobinson in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-11-2003, 11:05 PM
