Results 1 to 14 of 14
Thread: Climate control changing by itself '98 vt berlina 3.8 ltr v6
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Angry Climate control changing by itself '98 vt berlina 3.8 ltr v6
    A mate of mine has an issue with his climate control('98 VT BERLINA 3.8 LTR V6), it changes from what ever setting its on to defrost when ever you change throttle positon then when you back off it goes back to normal?
    Any ideas as it really bugs him with the hot weather it make the air/con worhtless.
    Thanks for any help Pat.
    vt berlina
    Jan 2008
    Quote Originally Posted by Da_rooster1980 View Post
    That would be caused by a vacuum leak, it could be the check valve at the back of the engine, the vacuum tank behind the glovebox, the vacuum solenoid pack under the dash or it could be one of the vacuum actuators.
    A vacuum pump like a Mityvac is good for tracing these sort of leaks.
    If it's the solenoid pack or one of the actuators, good luck because you need to remove most of the dash to replace them.
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Smile
    Quote Originally Posted by convas View Post
    Thanks i'll pass the info on to my mate!
    VY 04 II 3.8
    Jan 2009
    Shit, I've got the same problem with my VY Berlina! I always have my mode set on face and foot outlets and when I accelerate it blows out of the windscreen vents but quite often when it goes back to normal it blows hot air out of the floor vents but cold out of the face vents.
    VZ
    Oct 2008
    i have the same problem in my vt calais..has anyone fixed theres up and what exactly was wrong?? who did you take it too?? a/c guy, auto electrician??
    VT berlina 5.7lt
    Mar 2009
    coasty's Avatar
    coasty is offline the voices told me to
    vz equipe & vt berlina both v6
    Feb 2008
    kanwal nsw
    vt berlina
    Jan 2008
    Quote Originally Posted by muneey View Post
    I fixed it myself, in my case it was the vacuum solenoid pack but I changed all the actuators while I was in there as you have to remove the dash to do it.
    I used a vacuum pump/gauge to track the problem.
    It was not too bad but I did have to evacuate the A/C but mine was empty anyway.
    The factory workshop manual comes in real handy if you want to attempt this.
    Static89's Avatar
    Static89 is offline I Am Ironman.
    VT Berlina S1
    Jul 2008
    Sherwood QLD
    omfg........ i dont think it botheres me that much now
    ParkwayDrv: the worst thing for a hangover would be vkc
    vt berlina series 1
    Sep 2008
    vt berlina series 1
    Sep 2008
    can you tell me where i might find the fan controller , mine only runs at high speed and i got supplied a fan resistor by mistake , , only to find out later i need a controller for a vt s1 berlina
    vt berlina
    Jan 2008
    Quote Originally Posted by banga View Post
    Assuming you have Climate Control, my understanding is the climate control module (lcd panel) sends a signal to the Blower speed resister which then controls the Fan speed.
    vt berlina
    Jan 2008
    holy crap looks like a bomb went off, i dont think ill bother now either
    If you are lucky it could be check valve or vacuum tank or maybe one of the vacuum hoses has come loose, those are not too had to check.
    vt berlina series 1
    Sep 2008
    okkk to get to the speed resistor i need to remove the dash ? is this correct , and yes i have climate control, thx for the info so far mate
  1. Changing from standard Airconditioner to Climate Control
    By Barrie in forum VY Holden Commodore (2002 - 2004)
    Last Post: 09-10-2008, 12:19 AM
  2. vr berlina climate control?
    By davo44 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-01-2008, 03:25 PM
  3. changing head unit & climate control
    By VS-Acclaim in forum Car Audio
    Last Post: 03-11-2007, 07:53 AM
  4. Vs Berlina Climate Control
    By thegrach in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-03-2004, 12:37 AM
  5. Changing Standard Air Con To Climate Control
    By Sambo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-01-2004, 07:21 AM
