Results 1 to 7 of 7
Thread: VX SS Dash Light Out
    VX SS
    May 2008
    Default VX SS Dash Light Out
    I have black vx ss with red dash and the dash does not light up at all at night and remains dark so im guessing the bulb is dead or something how do i replace it? can i do it myself?
    cheers
    VX SS
    May 2008
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by Slopehead View Post
    do i just follow this ?
    Blue LED Dash Conversion
    That's pretty much it but instead of the A/C panel you remove the instrument cluster, should be straight forward. I would disconnect the negative battery terminal to avoid any problems, but you will need your radio PIN if you have the stock unit.
    MY RIDE
    VX SS
    May 2008
    My radio doesnt even work i bought the car from the auction , it doesnt say it needs a pin but i just dont get any sound out of it at all. I cant really take the car to a electrical place cause its unregistered and it wont pass inspection unless the dash lights up....i mean i wouldnt be able to see it at night then.
    So do i just immediately remove the dash with the screws up top and follow the instructions after that? iLL disconnect the whole battery just incase.
    VXII SS M6 & Leather
    Nov 2003
    Warrnambool
    id check the fuses first.
    sounds like the cause since there are no dash lights at all (not just the cluster??)
    if the globes are blown (which i seriously doubt ALL of them are - so it isnt the whole problem), you mught be in for a shock to learn that the globes for the main part of the cluster are $11 EACH and the globes along the base of the cluster are $17 EACH from Holden - and yes, theres a lot more than 1 globe as well.
    Anyway, check the fuses and check the wiring as well, there may just be a wire or loom not plugged in.
    check from the battery back.
    VX SS
    May 2008
    the oil lights show the power lights show everything shows except the actual red dash does not light up and the light up the top of the dash that normally would appear when you have turned the lights on does not.
    Nov 2003
    Warrnambool
    ah ok.
    probably just a couple of globes.
    a cheaper option is to head to the wreckers and get a povo-pack cluster for $20-$30.
    that way you have some spare globes for later on as well.
  1. lpg light on vx dash
    By lembo01 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-12-2008, 06:54 AM
  2. Dash Light on vn ????
    By aaronleach18 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-12-2008, 05:32 PM
  3. Replacing dash light AND radio light
    By CLE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-05-2006, 05:39 PM
  4. Dash Light Warning Light
    By Bongo in forum Electrical Wiring / Questions
    Last Post: 07-10-2005, 08:17 PM
  5. VZ dash fog light warning light
    By Torquative in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-08-2005, 07:13 PM
