Results 1 to 23 of 23
Thread: VT Climate Control how to wanted
    VT S2 wagon Berlina
    Dec 2008
    Default VT Climate Control how to wanted
    I have to change the bulbs in my climate control buttons.
    I cant find a "How To"
    Any one got some information on doing this.
    Its 41 degrees here in Adelaide and I need to see what my climate control is doing at night.
    Thanks
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Take the dash facia off.
    unscrew the climate control.
    pull it out and unplug it from behind.
    unscrew the cercuit board from behind.
    change the globes.
    CALAIS LS v6 3.6
    Feb 2009
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I'm not sure on which globes they use but I can tell you that the sellers is reliable, I have purchased from him a couple of times before.
    MY RIDE
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    CALAIS LS v6 3.6
    Feb 2009
    the seller just told me that this bult will fix http://www.wardenjp.com/t5_3led8.jpg but i dont think so.. hmmm i cant take out the fused bulb, but do anyone know which bulb will fix in climate control of this model
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    I thought you meant it was a digital climate control.
    To remove the globes..
    1. Undo two screws from the shifter trim. (you will need to remove the rubber insert) The screws are located either side of the cigerette lighter socket.
    Then remove it by lifting from the oppisite end. (it will slide up and out)
    2. Undo the two screws holding the compartment in and remove the compartment. (just slides out)
    3. Undo the screws holding the dash facia in. (as shown in pic below)
    4. Pull the dash facia out carefully. You may need to yank it a little.
    As it pulls out you will need to get your hand behind it enough to undo the wire plugs for the headlight switch, hazzard switch and mode buttons. (If need be you may need to remove your stereo if it is in the way of the facia)
    5. Undo the two screws holding the climate control in.
    Pull it out enough to get in behind it and you should now be able to reach the globes.
    You will need a very small streight edge screwdriver to unscrew the bezzels.
    CALAIS LS v6 3.6
    Feb 2009
    thx ill try.. and more thing that power buttons have so smaal globes.. can I replace them?
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Quote Originally Posted by faisal27 View Post
    Not sure which power button your referring to.
    But if your referring to the actual power button next to the gear shifter then its the same as the ones behind the climate control if yours is a series II. And yes they are small.
    But in the series 1's the power button globe bezel is smaller than the climate control.
    Best way to find out is to take it out
    CALAIS LS v6 3.6
    Feb 2009
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    woops im sorry... i was saying about Power Window buttons?
    Ahh ok lol
    I wouldnt have a clue about the power window buttons. Mine is all manual, However feel free to create another thread and someone else who knows will be able to answer that one
    CALAIS LS v6 3.6
    Feb 2009
    hey these are the globes which are used by my climate control
    i will post one more picture... can anyone help finding them?
    CALAIS LS v6 3.6
    Feb 2009
    CALAIS LS v6 3.6
    Feb 2009
  15. #15
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Your local auto shop should sell them.
    If not, Your local chev dealer should be able to import them from Austrlia.
  16. #16
    CALAIS LS v6 3.6
    Feb 2009
  17. #17
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    They are probebly imported from China to Australia then exported from here.
    If you know which ones are blown you'll only need to replace the blown ones.
    Though an auto shop wouldnt be much less price wise.
  18. #18
    CALAIS LS v6 3.6
    Feb 2009
    i removed the dash board and only two globes were working inside climate control. Well the mechanic changed it two months back and placed some toyotta globes and they got damaged in few weeks, i removed the climate control and changed the place of working globes and put the wires again when i turned on the lights, smoke came out from climate control and ILLUM. fuse damaged i replaced the fuse and turned on the lights and none of the globes were working in CLIMATE CONTROL... only two light work which works when ac is turned on and heater for rear window.
    do you think the climate control got damaged or the just the globes? should i buy 5 globes and take my chances..?
  19. #19
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    what did you replace the blown globes with?
    Im pretty sure theyve got to be 12v/1.2w
    I dont think the climate control curcuit board would be damaged, I think the globes that you replaced them with were different and have burnt out.
    Double check the voltage and wattage of the globes.
  20. #20
    CALAIS LS v6 3.6
    Feb 2009
    hmm i changed the globes, just changed the bulbs from holder. and placed them back in climate control, ONLY AC globe was worked for 5 second and the smoke came out again from AC button and the only globe thas was working stopped working.. Do you think its climate control board is damaged? im worried how much is the climate control? and how can i replace to digital climate control?
  21. #21
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Yeah sounds like the board it self is stuffed.
    If you can get on ebay you can buy a new or used one cheap (the whole climate control dials that is)
  22. #22
    CALAIS LS v6 3.6
    Feb 2009
    i was thinking is it possible to light six globes in climate control thru other place like connect their wires with other working globes in dashboard
  23. #23
    Olympic VT Commodore
    Apr 2010
    Same smoking issue happened to me...help please..
  1. Climate Control
    By newo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2008, 09:05 PM
  2. VS Climate Control
    By rus in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-12-2006, 05:09 PM
  3. Climate Control
    By Charg'd in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-05-2006, 02:22 PM
  4. Cruise Control and Climate Control?
    By Mr_mystikal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2006, 06:29 PM
  5. What exactly is climate control?
    By DavidPartay in forum The Pub
    Last Post: 01-02-2005, 05:58 PM
