Results 1 to 2 of 2
Thread: installing pedal box
    vt
    Oct 2008
    Default installing pedal box
    ok.. im half way through putting the dash back in, and ive just come to another problem of..
    will the dash need to be out for the pedal box to be put in ? and for the hole to be cut for the clutch slave ??
    im getting a manual conversion done by the way.
    also, does anyone know if the dash needs to be in or out to get the wireing loom swapped over? i want the electric options from my s-pack into my current executive, power windows, seat, etc..
    does anyone know if the dash needs to be in or out for that also ??
    thanks folks.
    VT R8/VU SS
    Mar 2004
    Hi mate;
    I did a similar swap recently; from memory there are 3 wiring looms; if you want to swap all 3 over you will 100% need to remove the dash pad.
    In regards to the pedal's, I *think* it would be possible to remove it without taking out the dash, but you would need to be a bit flexable. I also think there is a grommet in the wall for the clutch, but dont quote me on it.
    I would leave the dash out until the pedals/cables are in.
  1. accelerator pedal
    By 94calais in forum General
    Last Post: 21-11-2008, 09:52 PM
  2. WTB: VN-VS Manual Pedal Box [VIC]
    By The_Monk in forum Swap / Wanted to Buy / Trade
    Last Post: 15-03-2008, 08:13 PM
  3. Pedal box
    By maginoodle in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-05-2006, 06:58 PM
  4. Low brake pedal.
    By edgar in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2005, 12:25 AM
