Results 1 to 7 of 7
Thread: Vx Series 2 Ecotec Engine Bay Noise
    Hot-Rod's Avatar
    Hot-Rod is offline SuPaFlY -LiV3 Surviv3 Di3
    VX Commodore Series 2
    Sep 2005
    Oz
    Unhappy Vx Series 2 Ecotec Engine Bay Noise
    Hi everyone. Just recently had a S/C installed. Since the install i have had a strange high pitched noise occur. I am guessing it might be a pulley on it's last legs.
    Need second opinion on this, i've searched for pulley related issues on the forum and none of the noises compare to this noise.
    Attached is a link to a video of the noise. 28 secs left in the video you can hear the noise start. When the engine is turned off the noise persists for a short period of time before dieing away. The noise disappears under throttle above 1600rpm and returns when rpm falls below this.
    Noise from Engine Bay video by holden-bloke - Photobucket
    I've already spoken to the S/C manufacture and he is certain the S/C is not the cause.
    Attached Thumbnails Attached Thumbnails Vx Series 2 Ecotec Engine Bay Noise-engine-bay.jpg
    sxc_sound's Avatar
    sxc_sound is offline getting Kustom
    VT Series 2 S pak
    May 2008
    Parkdale
    you could try watching it as someone turns the car off, i was pretty sure that the belt stop spinning pretty much instantly, so you could tell if it was a pulley making the noise after the car is off as the belt stops. Or if the belts stops straight away and something else is making the noise, sounds like you sucked a mouse or something into the intake lol.
    04 VZ Exec, HX Kingswood, VB Comm
    Aug 2008
    Sydney Easter Suburbs
    We had that exact same thing happen to our car, it turned out it was one of the pulley, the one where your camera is viewing.
    cost $61.50 from holden i think, it sounded exactly the same except the loud sound that your experiencing was only appearing for us when under acceleration.
    VTS5's Avatar
    VTS5 is offline TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    Take the belt off,start the engine (dont worry nothing will happen) no noise means S/C OK, one of the pulleys no good.Normally the one under the s/c goes off first very common.Replaced mine about a year ago ($5 from wreckers ).
    Hot-Rod's Avatar
    Sep 2005
    Oz
    I took it around to a mechanic yesterday. He reckons its not a pulley cause the noise continues after the car is switched off????
    Can anyone tell me if a pulley would continue to make a noise for a few seconds after the car is off??? Do the bearings continue rotating after the car is switched off or not??
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    Could it just be an air leak in the intake, or something caught in the intake which is acting like a reed when the manifold has negative pressure?
    That would explain why it lasts a few seconds after while the pressure equalizes, and when you're on the throttle you'll quickly go to positive pressure with the blower.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by danja View Post
    I agree with this diagnosis. I would be looking for some sort of air leak around the S/C. Definitely not a pulley or the belt.
    MY RIDE
  1. Convertting to a series 1 engine from series 2 AND question about oil pick up
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-10-2006, 07:37 PM
  2. Series 2 V6 engine noise
    By mischf in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-08-2006, 10:54 AM
  3. Please help - possible reasons for noise from engine in VY series II
    By Laila in forum VY Holden Commodore (2002 - 2004)
    Last Post: 21-06-2006, 09:25 PM
  4. low km ecotec v6 - ticking noise
    By evil_monkey in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-05-2006, 07:26 PM
  5. VN 3.8l series 1 engine noise
    By mootavic in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-01-2006, 09:19 PM
