Results 1 to 12 of 12
Thread: Hey
    WH Statesman 5.7Lt
    Feb 2009
    Angry Hey
    Hey yall dose anyone have a problem with there windows ratteling in the VT or other modles , is there anyway to fix this problem it is sending me crazy
    I have 2 cars VZ sv8 6 litre and VU ute 5.7 litre
    Sep 2008
    My VU ute window rattles when its half way down, tried fixing it but its still there its annoying
    WH Statesman 5.7Lt
    Feb 2009
    Exclamation yeah
    yeah i got a WH statzman and about half way up or so . or when i have the volume up it justs rattels ????? pain in the ass isen it
    VX 'S' S1
    Apr 2005
    South East,Victoria
    I replaced the plastic runners in mine and it helped a lot. The both were worn and they slop around in the tracks when the window was down . They only cost a couple of bucks each . ( 2 per window ) The guy at the parts desk said it was a prick of a job as you have to drill out the rivets to pull it all apart then get the plastic runners pressed in then rivet it back in . I found it easier to pry out the old plastic runner then grease up the new one , slide it on then use a small G clamp to pop it in place . Takes about half an hour for each window from start to finish
    DanVN's Avatar
    DanVN is offline Cruizin' in style!
    01 WH Statesman International 5.7L
    Nov 2007
    Western Suburbs, Vic
    Mne makes a horrible grinding/ squeak noise when it gets near the top (Drivers only) Sounds horrible then creaks for a little bit after.
    Anyone else got this, or a solution?
    vx acclaim wagon
    Feb 2009
    try some silicone spray on the rubber seal that the window runs up and down in. just a light spray.
    good luck
    MikesCalais's Avatar
    MikesCalais is offline Trust me, I'm a Doctor
    VE Calais V International
    Dec 2008
    mine does that too.. half way up it makes this really loud click/clunk noise n actually moves inwards haha.. but it only happens every now and then, and only drivers side, but when its down, no matter how little, any bumps/the radio make it rattle.. im sorta just used to it now
    VX 'S' S1
    Apr 2005
    South East,Victoria
    My passanger side window has just started to do it too . I pulled off the interior door panel and found that the winder mechanism had popped out of the white plastic clip . I just snapped it back on and the noise is gone but i did notice that the plastic clip was worn so it will need to be replaced but for now no more noise
    VX Calais & VP Executive.
    Oct 2008
    Quote Originally Posted by DanVN View Post
    yeah i get that. its like it thinks its trying to go through the door. haha
    vt berlina series 1
    Sep 2008
    my one stops about 3 inches from the top after making a hell of a racket, i took the door panel off but cant see into the inside to see where the mechanism is , any ideas what i can do to fix this photos would be good , there was a pictorial posted yesterday for a vz but it didnt show the internals
    99' VT Commodore Equipe
    May 2007
    do you have scratches on the window when the squeek/grinding noise goes on??? could be the rubbers
    DanVN's Avatar
    Nov 2007
    Nope no scratches on the glass :S
    Drivers door has shutup since i had the trim off and now the passenger side has started (had that trim off as well ... *sigh*)
