Hi I have a VT Supercharged Calais, and was wondering if anyone could help me with a problem i have. I would like to know if anyone knows how to clean the oil out of the water through the engine block and radiator. I think the problem is to do with the Inlet Manifold Gasget. Does anyone know of this problem or has dealt with it in the past?
Also would this cause the engine from overheating, and water running out of the overflow?
If it was ur inlet manifold gasket the water/coolant will evaperate and youll find yourself having to top it up all the time.
Also the inlet manifold will not release oil into the coolant. The head gasket however will.
Check when you start the car from cold if its blowing white smoke.
Also check your engine & transmission oil to see if its a milky color.
