Results 1 to 8 of 8
Thread: Help from VX owners! Need info installing VX manual boot release cable on VT
    VT Berlina 1998, ECOTEC V6, Factory LPG
    Jan 2007
    Default Help from VX owners! Need info installing VX manual boot release cable on VT
    Hi Guys,
    I have recently removed my VT red reflective decor panel from my boot, and replaced it with a VX executive decor panel.
    This is fine, and all is well... however if my electronic boot solenoid fails I won't be able to get into the boot since the VX decor panel doesn't have a hole for the boot key lock! I believe the VX has a manual boot release cable, which can be operated by dropping the middle seat and pulling on a yellow ring which will manually open the boot in case of electrical failure.
    I have bought one of these manual boot release cables from my local holden spare parts store for $25. Now, I need help installing/fitting it.
    Can anyone please explain how the VX manual boot release cable is installed? Photos, scanned pages from manual, good write ups would all be appreciated!
    Cheers.
    Jan 2007
    Can anyone help with this? I'm scared the electric boot solenoid will fail and i'll be locked out of my boot. I Can't even climb through the middle of the back seat, cuz i've got a whopping huge LPG cylinder blocking the way!
    HSV +6
    Mar 2006
    Mornington Peninsula
    Jan 2007
    Quote Originally Posted by And_ROOS View Post
    Erm, wasnt there a button for the boot in the glove box?
    Yes, there is a button in the glovebox, but it is electrical and also operates the same electric boot solenoid that the remote key boot release operates.
    I need a "plan B" for WHEN the electrical solenoid stuffs up. The VX has a cable release for when this happens.
    sxc_sound's Avatar
    sxc_sound is offline getting Kustom
    VT Series 2 S pak
    May 2008
    Parkdale
    id like to know this too, i have a plank of wood bolted arcoss the centre seat, and i have the vx garnish put on, A manual release would stop the worry about it. Im sure a gregories manual would have it in it? but i dont have one
    VYII BERLINA
    May 2010
    Question Emergency Release Cable
    This looks to be an old thread and I have'nt seen any answers yet. I've just bought a VYII Berlina and it looks like someone was locked in it's boot. The cable has been pulled through and the right side wheel well has been kicked in. I bought a second hand cable in tact and now I have to install the item. The cable handle is removeable supposedly to allow you to thread it through the bootlid reinforcement cavity to the right side hinge. From there it's a mystery where it goes. It appears to run behind the backrest of the rear seats, but if thats the case, wheres the mounting point for the ring end of the cable? Any help would be appreciated.
    vx s
    Sep 2008
    auckland nz
    it mounts up on pasanger side up high in the fold down rest thing .
    i can have a better look 2moro maybe but i only have my phone camera so any pics will be rather lame .
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    The cable runs along the drivers side boot hinge and the ring you pull to open the boot is on the drivers side when you open the armrest on the back seat.
    Attached Thumbnails Attached Thumbnails Help from VX owners!  Need info installing VX manual boot release cable on VT-boot-release-001.jpg
  1. Installing Electronic Boot Release
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-08-2011, 12:02 AM
  2. installing power boot release.
    By VRV6BT1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-08-2008, 08:38 PM
  3. Boot Release Cable
    By jafo in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-05-2007, 05:54 PM
  4. Installing Electronic Boot Release InTo VS
    By nolim8ts in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-04-2007, 12:41 AM
  5. vx fuel cap cover release cable
    By mikespurr in forum General
    Last Post: 20-03-2006, 10:18 AM
