Results 1 to 9 of 9
Thread: steering rack boots
    vx supercharged
    Feb 2009
    Default steering rack boots
    just a quick question can you change the steering rack boots without taking off the steering ties,thanks in advance
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    You will need to remove the tie rod ends. It's not very difficult to do yourself.
    MY RIDE
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by dannyn12 View Post
    Yeah the tie rod ends have to come off in order to slide the new boots on, count the number of turns it takes when taking it off, so when you re-assemble you can get the alignment pretty close by putting it back on the same amount of turns. But get a wheel alignment done ASAP.
    vx supercharged
    Feb 2009
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    thanx guys is there a special tool required to remove the tie rod end?
    No but the ball joint can be a pain sometimes, usually comes out with a few hits to the side of the steering knuckle with a hammer
    MY10 SSV UTE
    Dec 2006
    Melb
    Default ...
    changed mine sometime last year and added these heat shields on them
    these are the pacemaker brand ones, most ppl using the difillippo ones say there noisy.
    im sure i have photo's of them fitted, ill have a look later on
    vx supercharged
    Feb 2009
    when removing the ball joint can you mark the nut and the thread in is orginal position with a marker
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I bought a tie rod end remover from Supercheap. I can't remember the price but I think it was cheap. You can remove them without the tool but the tool causes no damage.
    MY RIDE
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    You don't need to remove the ball joint but you can mark the thread on the tie rod.
    MY RIDE
  1. will a vp steering rack fit a vr
    By eaton v8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-09-2008, 10:06 AM
  2. oil line from power steering to steering rack
    By onmy6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-12-2007, 10:08 AM
  3. Keep a eye on your steering boots
    By f_vos in forum VY Holden Commodore (2002 - 2004)
    Last Post: 15-10-2007, 06:23 PM
  4. steering rack
    By homer simpson in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-09-2007, 09:56 PM
  5. Power steering boots, inner tie-rod ends
    By jack.mc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-10-2005, 11:01 PM
