Results 1 to 19 of 19
Thread: vt overheating
    vt series II v6 auto
    Sep 2008
    Default vt overheating
    99 vt series 2 big problem with it overheating, i have had a new radiator and thermostat put in and still heats up.
    what it does...
    if i pull up at a set of lights for a long period of time or in heavy traffic the temp gauge rockets upwards and the hot warning light comes on.
    but as soon as i start driving the gauge drops dramatically?
    It uses about a cup of water a day and strains a bit when starting sometimes but starts still.
    my mechanic is stumped and suggests a water pump but i dont want to keep paying for things to be done to it that dont need it.
    any help would be appreciated?
    Cheers Peter
    98 VT Wagon
    Oct 2007
    Not a head gasket is it? I had similar symptoms and it was the head gasket.
    Cheers, Daz.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Did he bleed the system to get rid of any air. This could be the problem
    MY RIDE
    Sep 2008
    hmm upon a quick inspection i have found the infamous white gunk under oil cap. how much should it cost me to fix it or am i better off flogging it off to a used car salesman
    98 VT Wagon
    Oct 2007
    Depending on how much water is under the cap. Just make sure it's not just condensation first, take it back to the mechanic and get him to check the pots, do a compression test and/or a pressure test....This will give you a definitive answer as to a head or head gasket. A mechanic shouldn't charge more than say $70 to do it. Check the Dip Stick for traces of water.
    If it is a head, you have to do both heads. An estimate would be around $800 per side, someone else will know exactly how much. When i did my gasket i just put it a reco motor, bear in mind mine had done 300,000 K's.
    Cheers, Daz.
    Sep 2008
    when it first started overheating i had a different mechanic check it over, pressure test was good and also did the test where he put the device in the radiator to check for fumes or something and that too was ok. the gunk seemed to be an off white material about as thick as shaving cream about a fifth of a teaspoon. no traces of water on dipstick???
    98 VT Wagon
    Oct 2007
    Another tell tale sign is little bubbles whilst running with the radiator cap off. Anyway you had the tests done, but there's water there. It may have been a build up over time, perhaps clean the cap and monitor it over the weekend. Sort of run out of idea's I'm sorry.
    Sep 2008
    thanks i will be going to my gfs uncle again next weekend for pink slip so will test it again and just monitor it o supose will post any results
    thanks
    Sep 2008
    ok got held up at lights and it started overheating amd temp gauge rose up, i put it in neutral and picked up the revs and the temp gauge dropped back to normal???
    my car is abnormal
    i honestly dont know?
    would the water pump need replacing anyone
    cheers
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by crew.man View Post
    my car is abnormal
    cheers
    It is a possible that the internals of the water pump are badly corroded and not circulating the coolant fast enough until the revs pick up.
    MY RIDE
    vx executive
    Apr 2008
    Sep 2008
    fans coming on yeh i am kinda leaning towards the water pump but how am i losing water?
    adamc11 is offline Donating Member
    VY SS
    Feb 2008
    E. & W. Suburbs Melbourne
    Quote Originally Posted by accentstencil View Post
    This could be the case.
    I think your head gasket is gone... if your seeing foam under your oil cap, even if it isn't heaps, then this points towards your gasket. If your having problems starting the car, then this is also a sign. Each time you turn the car off water is probably leaking through the hole in the gasket into the cylinder and this has to burn off each time you start your car. This is why you are losing water. A good way of testing this though (which doesn't always work, worth a try though)... Start your car, run it for a minute or so, then turn it off and start it straight away. Now, turn it off and leave it a few minutes then start it up. If it started fine when you turned it off and on quickly, and didn't start as well after leaving it off for a few minutes, then it is probably your head gasket.
    I would say if your attached to your car and have done things to it, then just spend the 1-2k or whatever it costs and change the gasket over. Maybe put on an aftermarket one so it doesn't happen again =)
    Sep 2008
    VY SS
    Feb 2008
    Find out what it costs to have it fixed, ring a few places. You will probably get a shit trade in amount so it might be worth fixing it, unless this gives you a reason to get something newer
  16. #16
    carless for now
    Feb 2007
    perth,Western Australia
    if ya trade it in like the way it is you will prolly get next to nothing for it
  17. #17
    VY SS
    Feb 2008
    If it's not too bad they won't even realise. Half the dealers don't even drive the car they just give it a visual inspection and make you an offer.
  18. #18
    Oct 2003
  19. #19
    VT Commodore
    Nov 2008
    Or the Inlet manifold....
    Head gaskets dont really blow on iron heads.
  1. Air Con and Almost Overheating
    By Feral01 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-10-2010, 04:03 AM
  2. overheating please help
    By joshooaahh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-07-2008, 07:13 PM
  3. vp overheating :(
    By RIC_VP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-05-2008, 12:30 AM
  4. Overheating?
    By Mr_Slim in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-02-2007, 03:07 PM
  5. Overheating
    By Turbo_dreams in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-04-2006, 09:37 PM
