Results 1 to 7 of 7
Thread: warning light
    Supercharged 6 Wh Statesman
    Oct 2008
    Default warning light
    hey guys ive had a warning light come up the last 3 times ive fueled up but only stays up for 2 secs after i have started driving...
    the light is the one in brackets has - round a circle with the square joined to the top and a ! in the middle... sorry bout the explanation of it...
    does anyone know what this warning code is?
    cheers
    daron's Avatar
    daron is online now wizfiz
    VE SSV
    Mar 2006
    adelaide
    Oct 2008
    na mate there are 2 in brakets that one is the handbrake.. the other light in brackets is the one that is lighting up
    vt series II v6 auto
    Sep 2008
    do you have an owners handbook or know of someone that does? most have details all of warning lights?
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Then it must be the globe failure warning light. If so it means one of the rear globes has blown or has a bad contact. Brake, parkers or number plate light. If it comes on when you brake, it is the brake light that has blown, if it comes on when you have your parkers or headlights on, then either the parkers or number plate globe has blown.
    MY RIDE
    VE SSV MY10
    Jun 2006
    looked in my calais hand book and it is rear lamp bulb fail light u might have bad connection the tail lights for it to turn off when u start driving it will also illuminate for a few seconds when u turn the ign on
    Oct 2008
    thanks guys i will keep an eye on it sounds like i might have a bad earth somewhere then cos it just flickers done it about 3 or 4 times but only for 2 or 3 secs..
    cheers
  1. Alternator Warning Light & ABS OFF Light
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-01-2007, 10:10 PM
  2. Tail light warning light
    By G4orce in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-08-2006, 06:27 PM
  3. Tail light Warning light
    By G4orce in forum Electrical Wiring / Questions
    Last Post: 26-07-2006, 08:15 AM
  4. 'Rear light bulb failure' warning light
    By Misaprop in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2006, 03:07 PM
  5. VZ dash fog light warning light
    By Torquative in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-08-2005, 07:13 PM
