Results 1 to 15 of 15
Thread: fans inside bonnet
    CALAIS LS v6 3.6
    Feb 2009
    Default fans inside bonnet
    i want to know that does the 2 fans inside the bonnet always work? because i noticed that they work when i turn on the air condition
    '97 VS Commodore + '98 E36
    Apr 2005
    CALAIS LS v6 3.6
    Feb 2009
    hmm are you sure? coz there is alot of heat coming out from the bottom of the car when I open my door..
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by faisal27 View Post
    Yes, ridah is correct, both fans will come on when you turn on the A/C and they will stay on until you turn it off.
    MY RIDE
    CALAIS LS v6 3.6
    Feb 2009
    i said is it because of fans that alot of heat is coming from bottom of the car and it feels like its burning when i open my window or open the door
    04 VZ Exec, HX Kingswood, VB Comm
    Aug 2008
    Sydney Easter Suburbs
    all holdens that i've been in have large amounts of heat coming from the bottom of the car, depending on how they are driven / what options are enabled (eg air con)
    sxc_sound's Avatar
    sxc_sound is offline getting Kustom
    VT Series 2 S pak
    May 2008
    Parkdale
    when i turn on a/c on, only the passenger side fan comes on, and when its hot, they both come on...
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    [QUOTE][/QUOTEi said is it because of fans that alot of heat is coming from bottom of the car and it feels like its burning when i open my window or open the door
    Correct!, the fans draw in air from the front of the vehicle, picking up heat from the radiator as they go, this air has no where to go once in the engine bay, except out the bottom and this is what you are feeling.
    Pablo
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    Yea, couple of times i've gotten out of my car with the engines off and felt the heat as i've gotten out! Don't need the fans on to feel it!
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by sxc_sound View Post
    Both mine come on even, when stone cold, with aircon on.
    MY RIDE
    VP Exec
    Jun 2005
    Some of the criteria for the fan switch on, for VT and VX at least, is in immortality's how to on fitting a fan over ride switch in VN-VP.
    In during either VT or VX production (I can't recall which) the fan operation was changed from both fans having two speed operation, reflecting cooling requirement, to one fan operating under conditions of low cooling requirement and both operating under conditions of high cooling requirement. I don't know what VY or VZ are meant to do but can't see why they would be very different.
    VTS5's Avatar
    VTS5 is offline TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    It shouldnt be surprising, specially where you live ..
    CALAIS LS v6 3.6
    Feb 2009
    Quote Originally Posted by VT_Acclm View Post
    lolz.. im serious it feels like my engine is burning when I open the window while driving
    CALAIS LS v6 3.6
    Feb 2009
  15. #15
    sway9 is offline The Rejectz Commodore
    99 VT, Mazda 3 SP23, Hyundai Getz 1.4ltr
    Dec 2008
    Albion Park NSW
    so is there anyway that i can make fan work continuesly?
    yea by pass the automated circuit and hook them up to 2 switches in cabin preferably somewhere near your steering wheel or on your door. why would you want them to work continuesly anyway?
    On the look out for my new VT 98
  1. need help! bonnet latch is broken and cannot open bonnet!
    By boourns in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-02-2012, 11:10 AM
  2. Bonnet release cable snapped how do i open the bonnet
    By S-Pac_Sam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2010, 09:07 PM
  3. Thermo fans into a VC
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-06-2009, 02:46 PM
  4. ZZ Top Fans
    By DANS_S4 in forum The Pub
    Last Post: 17-03-2007, 03:52 PM
  5. Tightening bonnet hinge(body end, not bonnet end)
    By NOGEN 3 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-03-2007, 11:28 AM
