i have a s1 vt acclaim and it has started missing and backfiring, when i looked at the car started at night time there was sparks coming out of the leads where it's not meant to. so i go and get new plugs and leads thinking the old leads were stuffed but its still happening so i'm thinking maybe the coil pack it only happens when i accelerate quickly or out on the highway with cruise on it happens and i just blip the throttle and its right and when it happens around town i just back off the throttle a bit. it's like it's missing until the spark gets to the right place, any help,ideas or suggestions greatly appreciated
i have the same problem too and been trying to get ideas for it aswell.... i think i just have to take it to holden to get them to diagnose it. but i know what you are feeling... just want to kane the car but it jerks and misses all the time.
mine does the same.. changed leads and plugs didnt help, checked coil packs didnt help, ended up gettin it on the diagnostic tool and found out my abs + trac cont. module wasnt functioning properly was told this wud fix the problem so i got it done paid like $1,500 didnt even fix it still does it
have no idea wat it is!!!!
If All Else Fails, Then You're Probably Driving A Ford
dude replace your coils with new ones same problem vq stato v6 fixed it up staright away thats is if the sparks are coming from coil to lead area? cheers
Ok fellas, to test your coil packs,
With the engine off, take the first 2 leads of the first coil pack and then start the engine, now have a look @ the metal tips on the coil pack, the spark should be jumping from tip to tip, if the spark jumps anywhere else then the coil is stuff/on its way out! If the coil is ok then turn engine off, replace leads and move onto coil pack num2 and so forth on number 3!
MY RIDE 96 calais
http://forums.justcommodores.com.au/...96-calais.html
ALSO MY 1972 VALIANT CHARGER IN THE BUILD
http://forums.justcommodores.com.au/...t-charger.html
well i checked the coil packs as mentioned above and they are ok i replaced my leads in exactly the same spots and then got in my car and now it's not doing it anymore??? maybe 1 of the leads may have not been making good enough contact
i'd still say you have a dud coil. keep driving it and see if it comes back. I had a dud coil and those symptoms came and went a few times. when i put a new coil on it fixed straight away ... $52 from Repco. but go to autobahn and get a MSD coil, or a supercharged coil from holden / wrecker for a better one.
yea bud as greenacc said maybe intermitten mine was went on for a week till it croaked al to gether but the spark was deff jumpn all over the place good luck dude?
my T/C light doesnt even come on when i press the button.. its stuffed aye
and this doesnt cause any damage to the engine?With the engine off, take the first 2 leads of the first coil pack and then start the engine, now have a look @ the metal tips on the coil pack, the spark should be jumping from tip to tip, if the spark jumps anywhere else then the coil is stuff/on its way out! If the coil is ok then turn engine off, replace leads and move onto coil pack num2 and so forth on number 3!
On the look out for my new VT 98
MY RIDE 96 calais
I changed my coil packs on the week end and it is running better. When i plant my foot more then half way it still jerks but only a little bit. it was better then when i put my foot for like 1/5 of the way and it was jerking. so i guess my coil packs are fine then. I have just changed the sparks and leads about 5 months ago. so would that be a fault in my engine now???
Yeah i would probably suggest that it's your injectors, given your plugs leads and coil packs is ok, a blocked injector will cause your engine to feel like it's missing a beat somewhere, light acceleration can make it worse!, run your fuel tank empty then fill up with about $20 of premium, pour a bottle of injector cleaner into your tank, and then rev your car for about 10-15 mins, if this dosn't clear it, replace injectors that are stuffed!
yes sweet i have not put the injector cleaner in for a while... it could well be that....
now would it be okay to get a full tank of optimax petrol in the tank and then back to normal fuel the next time?
Can you also have optimax + injector cleaner in the same tank of petrol??
yeah, course you can. Its also possible your fuel filter is getting blocked up and needs replacing. Cheap place to start if it hasn't been done in a while.?
I was told by a mechanic that faulty leads can damage coils aswell, so its good to keep your leads/plugs in reasonable condition to avoid other problems!
MY RIDE 96 calais
So have half a tank of normal fuel at the moment.... would it be alright to fill it up with optimax petrol from now?
Also check in plug that connects to Coil Pack is it clean and not corroded
The small connectors can corrode and cause poor connection
This can sometimes cause this issue
Use some WD40 to dissolve any corrosion
I was advised this by a good auto electrician who didnt want to rip me off just to fix something that wasnt broken
Hux
it is the coil pack, mate! replace it and see the difference immediately!
so is that okay to just spray some of that WD40 straight into the leads plug??
