Results 1 to 19 of 19
Thread: Busted seat pockets
    VX Acclaim II
    Feb 2009
    Default Busted seat pockets
    Boys and Girls...
    Both of the seats in my VX have busted pocket things behind them, I take it this is common? The plastic rail down the side of the pocket has broken where the screw threads in, and the elastic in the pocket is stuffed too.
    Are they easy to replace? Seems like they're screwed in from inside the seat somehow, I'm not sure if I can get to the screws to take them off. Its annoying as, looks shyte!
    michaelw's Avatar
    michaelw is offline Donating Member
    VX S2
    May 2005
    Newcastle NSW
    Don't know how to fix but one of mine broke sometime in the last few weeks. I am going to get it fixed at the dealers so I'll tell you how much it costs to get ripped off to get it done!
    Mike
    VX Acclaim II
    Feb 2009
    VXII SS M6 & Leather
    Nov 2003
    Warrnambool
    they are called MAP POCKETS.
    they are about $50 each and come with everything you need to replace them.
    they are screwed on from the inside too.
    remove the HIGHEST twist knob on the side of the chair (not the bottom twist knob) and then lift the plastic (that is under the twisty knob that you just removed) over the metal bar that the knob came from.
    now, grab the bottom middle of the plastic seat back and pull it towards you.
    you will hear a snap and then you will have the plastic seat back in your hands.
    the snap you heard are 2 white plastic clips that hold the backing to the seat.
    dont worry as there is no way to remove the backing without breaking them - plus, these 2 clips are included in your new map pockets!.
    remove the old map pocket and replace with the new one.
    when returning the backing to the chair, make sure you have the top 2 hooks in properly, then push the base inwards, lift the side over the metal bar and replace your twist knob.
    job done.
    5 minutes each side.
    sxc_sound's Avatar
    sxc_sound is offline getting Kustom
    VT Series 2 S pak
    May 2008
    Parkdale
    that's a perfect description of how its done, i bought my car with a map pocket missing, it cost me $37 for a new one, but i had to buy the white clips separately, $2 each if i remember correctly.
    VX Acclaim II
    Feb 2009
    Map Pockets! That's them.
    Thanks heaps for that, will replace both of them. Is it worth getting calais ones or something? Or are they all the same?
    Mental Note: don't put MagLite in map pocket as it broke it.
    vx s
    Sep 2008
    auckland nz
    o this seams so easy dam i mite have to do mine
    i was just going to leave them like that lol
    michaelw's Avatar
    VX S2
    May 2005
    Newcastle NSW
    Got my car serviced the other day and they only charged me 20 labor to fit them. Yes I could have probably have done it myself but I had better things to do.
    Mike
    Nov 2003
    Warrnambool
    map pockets are map pockets - doesnt matter if they are Calais or Executive, they are all the same.
    the only difference is the colour options.
    VX 'S' S1
    Apr 2005
    South East,Victoria
    I fixed mine with a set of seat covers ha ha
    H1GHROLLR's Avatar
    H1GHROLLR is offline CHEMICALLY SUPERCHARGED
    VX CLUBSPORT R8 LS1
    Feb 2009
    ROCKINGHAM,PERTH
    they look better with the map pockets taken off and few black plugs in the holes
    Sep 2004
    ive noticed in a matter of time if u use em for melways or have kids and baby seats at the back they will be screwd again, this is holdens fault for not making em more sturdy they are very flimsy esp for the melways which is a heavy book they should have made em more stronger!
    sxc_sound's Avatar
    VT Series 2 S pak
    May 2008
    Parkdale
    Quote Originally Posted by mrVT View Post
    they actully did make them stronger, they bought out a revsion of the first ones with larger mounting screws and thicker walls in the pockets to hold them on. I have one old one and one new one, side by side you can see the differnce in quality
    VT II S pack
    Dec 2008
    VX Berlina, VS Exec
    Mar 2005
    Quote Originally Posted by davway View Post
    job done.
    Outstanding description!!!! Thank you sir!
  16. #16
    VY S Sedan
    Sep 2007
    You can remove the seat back without breaking the clips.You can use a flat blade screwdriver between the seat and the backing at the bottom to push up and compress the clip tangs to release.I've done hundreds of them this way,but you're right,you do get new ones in the kit now.Originally the clips were seperate to the seat pocket.
    One thing to remember is that when fitting the revised type pocket to an older backing,the holes have to be drilled out to accomodate the larger pins on the pocket frame.
    If you don't do this,the pocket won't fit correctly - won't be flush with seat back.
  17. #17
    VY one tonner / gen3 / 6speed
    Jan 2009
    just left of hell
    Good thread, I probably would never have bothered to fix the ones in the wifes car, now I will.
  18. #18
    VT series II
    Mar 2006
  19. #19
    vxss vnss
    Jun 2009
    my kids broke mine,will have to replace them too
  1. seat pockets
    By superchargedvy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 29-07-2009, 09:29 PM
  2. Rear seat pockets
    By sxc_sound in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-09-2008, 08:06 PM
  3. magazine pockets how to replace on vt
    By Ballport1998vt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-11-2006, 11:05 AM
  4. Neons in the door map pockets.
    By fabz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-04-2006, 12:09 AM
  5. WTB: VR side door pockets
    By sparra_gump in forum Swap / Wanted to Buy / Trade
    Last Post: 24-11-2005, 09:03 PM
