hey guys,
ive been having some trouble with my sunroof. it started by opening when the car was turned off. and now it opened when i turned the car off and wont close.
any help please
i have an issue with the sunroof too... it closes but leaves a small gap. and has just been doing it lately so i have to press the close button on and off quickly so it closes properly and press it when i take the key out so it does't return with the gap. it sh##s me sooo bad.... anyone with the same problem aswell?
ive got it closed now. but if anyone has any ideas on what to do about it opening when the car is turned off please let me know.
I have a very similar issue (by the sounds of your description). Mine is in my VY Berlina. It opens & closes fine, but it's as if it doesn't lock into place. When the sunroof is closed and the car is switched off, you can place a little pressure on it and it will actualy leave a gap (big enough for water to leak in).
I'm going to try and find a local business or someone who deals with sunroofs so as I can get an idea of what the issue is before I know wht the resolution is. If I obtain any more info, I will let you know.
