Results 1 to 8 of 8
Thread: Brake Fluid / Caliper Problem
    VE Calais
    Sep 2008
    Cheltenham, Victoria
    Default Brake Fluid / Caliper Problem
    Gone to change break pads today as yesterday I found out that I should probably change my break fluid so while I was at it thought I may as well change my pads as well since I was going to do the fluid change over ....
    been Friday i had my younger brother with me helping me and i asked him to change the radio station and he put his foot onto the brake while I had the caliper off and one of the pistons came out (i have no idea why it came out all the way... as that has never happened before and I would think the slightest touch of the break pedal shouldnt have much such an effect) anyway..
    My guess i going to be.. no real issue here just need to put the piston back in and use a gclamp to push it back?
    My concern is that wouldn't it push alot of air back up the brake line?
    Should I change the rest of the brake pads now and worry about bleeding it at the end or should i bleed it now and then do the pads and should will it be okay to just force the piston back in even though it has come all the way out, oh and btw when it came out.. alot of brake fluid dispersed along with it this was the passenger front side too.
    thanks
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    You might as well let all the fluid drain out since you are going to change it anyway. The piston should go back in easy without the fluid, no G clamp should be necessary. Bleed it after you've changed all the pads starting with the longest brake line first, then work your way to the shortest.
    MY RIDE
    VE Calais
    Sep 2008
    i would assume by longest...
    passenger rear, driver rear, passenger front and then drivers front then?
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    When you push the piston back, undo the bleed nipple on the caliper to release the air.
    Also, ensure your hands are perfectly clean and have no mineral oil or dirt on them that will contaminate the piston rubber 'o' ring. Wash in metholated spirit any parts that need cleaning. The sequence is as you have determined above!
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    its normal for the piston to come out if you push the brake pedal while the pads are out.
    If you ever want to change the seals in the callpier, this is the easiest way to get the piston out. Which pads did you use ?
    VE Calais
    Sep 2008
    greenacc's Avatar
    VE Berlina
    Jul 2008
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    do u have abs? if so wouldn't draining the fluid cause the abs light to come on ?
  1. Brake caliper movement
    By VL-VP-VT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-05-2008, 11:28 AM
  2. Brake caliper types
    By Longman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-02-2008, 12:59 AM
  3. brake caliper question on my VT
    By werdy666 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-04-2007, 07:53 PM
  4. Brake Caliper Cover kit??
    By akcim13 in forum General
    Last Post: 09-03-2006, 04:30 PM
  5. Brake Fluid and Auto Trans Fluid.
    By Melchior3 in forum General
    Last Post: 20-02-2006, 11:49 AM
