Results 1 to 10 of 10
Thread: Aftermarket Power Windows
    VX Executive S2
    Feb 2009
    Gold Coast
    Default Aftermarket Power Windows
    Hi Guys,
    Am looking at aftermarket power windows for my dunnydoor. Anyone know a good supplier of a kit? Or has anyone fitted a kit?...
    Have trawled all over ebay for holden bits but now thinking aftermarket may be the way to go.
    Tez
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    You will need quite a few bits including door trims, motors and switches. You're better off finding someone with a car that has power windows wrecking and buy all the bits off them.
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    HBD VY BERLINA WAGON 5.7L
    Aug 2008
    Blairgowrie
    go to holden and order new regulators and then go to wreckers for looms and switches... aftermarket is shit get genuine parts
    Set of thongs
    Dec 2005
    Stonedville
    by the looks of it the front regs are the same as vn to vs ones , just look around i just picked up 2 front regs, 2 back regs, 3 door looms , set of central locking mechs, four steel door handles and the front window switches for 50 dollars all working
    VT Calais V6
    Aug 2007
    Don't understand why you would go aftermarket when you can get genuine second hand stuff quite cheap.
    VX Executive S2
    Feb 2009
    Gold Coast
    OKay, found a guy on ebay (the link that Archers suggested) reckon he can do a conversion kit for $550, He also reckons most of the time you dont need to change the BCM but if there is a problem holden can FLASH you existing BCM to run the windows???
    I also dont want to bother changing the door cards. So ill run the windows from the center consol and cover the holes with a holden badge or something. Old mate from ebay reckons a lot of people do this.
    Comments?
    TezVX
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I got genuine regulators, door looms and main switch of ebay for under $200. You just need to be patient and wait for a bargain. I have door looms to suit a VX for sale should you need them.
    You will need to connect the rear door switches because the rear windows won't work from the main switch without them connected. But there is probably a way around that.
    MY RIDE
    VX Executive S2
    Feb 2009
    Gold Coast
    okay, back to sifting through ebay then. Mite try some local wrecking yards.
    Tez VX
  1. power antenna and aftermarket stereo
    By vycalais in forum Car Audio
    Last Post: 22-01-2011, 01:06 PM
  2. Options..power seats... power windows??
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2010, 06:01 PM
  3. Aftermarket Power Window Parts
    By vt com in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-02-2007, 10:55 PM
  4. Aftermarket Power Windows
    By NORTI in forum Electrical Wiring / Questions
    Last Post: 09-08-2006, 12:11 AM
  5. aftermarket power window pics
    By crainy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-07-2005, 09:43 AM
