So I'm looking at replacing my Dual Mass Flywheel.
First of all, does the supercharged V6 (L67) have a different balance to the ecotec (L36)? I'm assuming it does.
Also after a bit of reading I have seen mentioned that manuals and autos actually had a different balance? Can anyone confirm this or otherwise? This may be why I've never been able to get rid of the vibration in my engine since the manual conversion.
Also, does anyone know how much an exedy HD clutch kit costs, WITHOUT the solid flywheel? I can't seem to find that info anywhere. I may be able to get a 2nd hand solid flywheel but probably would get a new clutch.
Found the info here:
Ecotec auto to manual
So the standard auto ecotec and standard manual ecotec are not the same! The cranks have different balance. I better get on top of sorting out a properly balanced one then...
This should be in the sticky!
