anybody out there know the steps involved in changing the water pump on my vt? couldnt find a how to thread???
cheers Peter
before u take off the belt, crack the bolts on the pump pulley.
take off belt
remove pully on pump
undo the retaining bolts
lever it off with a screw driver but be careful
scrape the surface area with a razor blade till clean
put on gasket
then reversal
cheers mate
be mindful it may be handy to drain the radiator and to use a light layer of gasket goo on each side of the gasket
In the Just commodores How-Tp section
Changing water pump VN/VP/VR
Its says for vn vp vr but ecotecs are almost identicle they use the same water pump
Originally Posted by Smidy
http://forums.justcommodores.com.au/...8-gonesky.html
i think i found the main reason for my overheating......
bUAHAHAHAHA
sure you know but just make sure you get all the old gasket bits left behind. best way is to get a razor blade, some carby cleanert and rag and some emery paper
dont forget to make a mudmap of where the drive belt goes , just to make your job easier when you finishing up
