Results 1 to 2 of 2
Thread: Lumina Speaker
    CALAIS LS v6 3.6
    Feb 2009
    Default Lumina Speaker
    hey guys I replaced my Lumina ls cassate player and installed a 2 din LCD well i noticed that my rear left speaker is not working anymore it was working before so i went to that guy who installed the LCD and he checked the wires and said the speaker is damaged, i dont know how it can be damaged itself maybe that guy did something wrong, can anyone know what could be the solution? and what speaker is used in the rear left door?
    VX S2 S-Pac
    Oct 2005
    easiest solution. take ur door trims off both back doors, swap the speakers and see which one isnt working. 30min job at max. if ur speakers blown you can replace them with any 6" speaker.
    If the left side still doesnt work when u swap the speakers (and assuming the guy checked the lcd is working) check the wires where they come out the car body into the door, sometimes that rubber boot over the wires bends the wrong way and gets squashed between the door and car body which can snap wires.
    VR through to VX wrecking in WA, must get rid of these!
    http://forums.justcommodores.com.au/...res-vr-vx.html
  1. 05 vz lumina
    By VZ05LUM in forum VY - VZ - WK - WL - V2
    Last Post: 11-01-2009, 02:42 PM
  2. 05 vz lumina
    By VZ05LUM in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-01-2009, 09:25 AM
  3. Replies: 6
    Last Post: 31-07-2008, 08:11 PM
  4. WTD - VS etc Speaker Door Pod Speaker Grills
    By lil_oneblue in forum Swap / Wanted to Buy / Trade
    Last Post: 08-01-2007, 08:38 PM
