Results 1 to 12 of 12
Thread: Quote from pot hole damage. Rip off?
    VZ Calais
    Aug 2005
    Mackay Qld
    Default Quote from pot hole damage. Rip off?
    G'day all,
    I just got the quote from a local franchise of a well known [bulldust] suspension outlet.
    First a little background.
    We bought the car in Melbourne a bit over a week ago, & were driving it back when we hit a pothole about 500k's from home. It hit hard on the p/s front wheel. Alignment is still very good, no shake or shudder throught the steering wheel, tracks true.
    The p/s front wheel is leaning in at the top [camber], & the steering makes a loud knock knock knock when turned left from centre.
    The suspension is relatively new. It is all 'name brand' from the same franchise.
    I took the car in for a check today, & i recieved this quote:
    Description: 5851 VR on bearing plate Qty:2 Price:44.00 ................... Value:88.00
    5030 commodore strut brg 2 35.00 .................... 70.00
    5409 H/D comm radius rod 2 68.00 ................... 136.00
    Urethane alignment bush 1 238.00 ................ 238.00
    5843 [bulldust] rubber bush 2 23.00 .................. 46.00
    5823 [bulldust] rubber bush 2 33.00 .................... 66.00
    pwr steer rack & pinion 1 440.00 ................. 440.00
    pwr steer flush kit 1 70.00 ................... 70.00
    wheel alignment 4 wheels 1 110.00 ................ 110.00
    fitting 1 595.00 ................. 595.00
    freight 1 40.00 ................. 40.00
    GSR sealed strut 2 508.00..........................
    Total: $2407.00
    I think these guys are having a lend of me!
    Why would the d/s strut, Z-bar, bushes, bearing cap & plate need replacing if the existing suspension is new?
    Why would a pwr steering flush kit be required if a new rack is being fitted?
    I look forward to your views.
    Cheers, Col.
    Last edited by coolngroovy; 24-02-2009 at 12:25 PM. Reason: added ...............for clarity
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    Pedders up to their usual tricks... if it's got dust on it, it needs replacing
    Looks like a rort to me, power steering rack should be about half that for a start, can't comment on what bushes would be needed without seeing the damage.
    Could be something as simple as a split bush on the swaybar link Get some 2nd opinions I'd say.
    VB SL/E
    Dec 2008
    NVE_069's Avatar
    NVE_069 is offline Vx Calais / Ve Berlina
    Vx Calais LS1 / Ve Berlina V6
    Mar 2005
    When i had to get my pwr steern rack an pump fixed costed me 650 fitted but thats not including the 170 i spent the day b4 for the pump as i thought cheaper to try that 1st lol wasnt it tho. so all up was just over 800 all up
    Always In Construction Mode!!!!!
    2007 VZ ACCLAIM WAGON
    Feb 2005
    St Clair
    VZ Calais
    Aug 2005
    Mackay Qld
    Just got the second opinion from a local shop.
    Parts needed: Strut, top bearing & bush, knuckle?, leaking rack, * he also pointed out the engine mount which is just starting to tear & a dented rim.
    Strangely, the Zbars & bushes look good.
    Unfortunately i will have to go back to 'bulldust' & buy some parts.
    Cheers, Col.
    danja's Avatar
    Jan 2006
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Pedders are excellent for their parts, just don't let them work on your car!
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    VN Executive
    Mar 2005
    Default Bulldust are a complete sale pitch.
    I have a VT Commodore. yeah their quotes are usualy about $2500 the Dicknician at The same place all Bulldust rammed a long bar under the rear suspension mount bracket and levered it down real hard and said hay look in their mate see how that rubber is torn that will need replacing. Well the only way this rubber should be inspected is after the rear suspension mount is removed as levering them down tears the rubber damper. so they actualy go ahead and inspect your car and while they are doing so they ar eactualy destroying your rubbers. about the only real inspection of broken rubbers that can be done on a vt commodores suspension damper/ rubber components is the front what used to be called torsion bar rubbers and while i was their the little idiot started poking them witha screw driver until i said you idiot they are filled with gel that once punctured are useless. and as for your power stearing if you are losing less than 200ml of ps oil a year that is pretty normal for a car over 160.000km.
    also nolathane is a great way of destroying any comfort your car still has so stay away from it. its cheap to buy lasts a little longer but not to the point of the vehicle having another full life. (its just BIg Red Cheap Hype)
    I am looking for a Supercharger For A VT V6.
    VZ Calais
    Aug 2005
    Mackay Qld
    Update:
    Bought bearing plate, bearing,strut from bulldust. [ i didn't think we could name them?]
    Bought knuckle from Holden $140?
    Bought reco steering rack $361 exch. [PIA to fit]
    Fitted all parts today. Wheel sits nice now. I will take it in for a wheel alignment tomorrow, then a roadworthy.
    We need 2 V- series calais rims. 18". Anyone?
    Cheers, Col.
    Edit: The Zbars look fine, so do the rubbers. The old strut was bent, & the top bearing had collapsed.
    VZ Calais
    Aug 2005
    Mackay Qld
    Update:
    I had the wheel alignment done this morning. Looks like 2 rims are bent.
    The car was also passed for roadworthy, with no faults.
    Happy days! Time to change the rego.
    Cheers, Col.
    danja's Avatar
    Jan 2006
    Glad it worked out a bit cheaper than $2,400
  1. Quote on vr tranny
    By Inkar in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-11-2008, 10:09 PM
  2. Crow Cam Quote
    By johnvtls1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-09-2007, 02:35 PM
  3. Quote of Quotes
    By dsnutz in forum Jokes/Humour
    Last Post: 18-07-2006, 04:39 AM
  4. Exhaust quote
    By Snotty in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-01-2006, 12:37 PM
  5. Quote of the day??
    By simmo 76 in forum Jokes/Humour
    Last Post: 07-12-2005, 12:18 PM
