Results 1 to 6 of 6
Thread: Oil Light
    chromic's Avatar
    chromic is offline Donating Member
    VT V6 Sedan, VY SS sedan
    Nov 2005
    Default Oil Light
    Hi,
    My oil light comes on sometimes when I brake hard and come to a complete stop. The light comes on, makes a noise, I start getting worried, then the light comes off.
    I checked the oil level and it is fine as I did an oil and filter replacement last week. The only thing is I used a cheap brand oil filter (cost me 4 bucks) instead of the ryco one.
    Could the cheap oil filter be the problem? In the whole time (9 months) I have owned it, this has only started to happen after the oil change. The oil has also been changed regularly prior to this.
    I have 2 cars VZ sv8 6 litre and VU ute 5.7 litre
    Sep 2008
    Sounds like the cheap oil you bought, my suggestion is always buy a good quality oil and oil filter, and I would probably do an oil pressure test afterward just to make sure all is o.k.
    Sep 2004
    looks like u need a new oil pressure pressure switch if lights turning on and off doesnt matter what oil u use it shouldent be making light go on and off.
    Sep 2006
    Yeah sounds like oil pressure switch. Does ur check engine light come on? If so u can scan the codes through holden or if u have a scan tool. And will tell you if ur switch is an issue.
    VTS5's Avatar
    VTS5 is offline TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    Quote Originally Posted by chromic View Post
    Hi,
    You've just struck a very common VT problem.Replace your oil pressure switch.That will fix your light problem,You also mentioned NOISE !!! What sort of ??? Tappet noise ? or what ?
    VT Acclaim
    Jun 2010
    Hey does anyone know where the oil sensor wire leads too? Mine has disapeared, the plug is there but with only one wire in it, I looked at a vs and the same sensorplug had three, so I am missing 2 wires to the actual plug, any ideas?
  1. Battery light & Check Engine light
    By Sledge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 06:30 PM
  2. vr calais head light and interoir light brake problem
    By lestat2220 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2008, 01:38 PM
  3. Berlina/Calais/Statesman Roof Inteior light into basic model with standard light
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-08-2008, 10:07 PM
  4. Converting VR Executive light to a VR Calais interior light...
    By sverzijl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-10-2006, 09:46 PM
  5. 'Rear light bulb failure' warning light
    By Misaprop in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2006, 03:07 PM
