Results 1 to 19 of 19
Thread: Help fitting 9.5" VE rims on rear of VT
    Y-Series Senator Signature
    Jan 2006
    Willall Racing
    Default Help fitting 9.5" VE rims on rear of VT
    Hi all,
    Just bought some Genuine VE 20's not GTS... and just thinking how hard it would be to fit the 9.5" rears on my senator.
    Offset is 57p
    Is it just as simple as buying some bolt on hub spacers from wheelworx?
    And fitting the rims in general, is it just drilling out the centres? or do i have to get different wheel nuts?
    Im hoping thiese would look pretty cool while being totally different and original
    nicko's Avatar
    nicko is offline Carbon Positive - DO IT!!
    75 cruiser ute
    Sep 2007
    sa
    My understanding with the machining of the rims is that about 2mm need to come off the inside of the VE wheel hub. A friend of mine has ve 18s on his vx and he used a lathe to machine the hub to fit.
    no longer a hoon by association - the commodore is gone
    Jan 2006
    Willall Racing
    dijm8's Avatar
    dijm8 is online now What You Looking At
    VZ SS LS3
    Jun 2006
    Jan 2006
    Willall Racing
    At least itl help putting some power down to the ground, wheelspin becomes annoying after a while
    MY10 SSV UTE
    Dec 2006
    Melb
    Default ...
    when are you getting them fitted mate? love to know how you go.
    started a thread the other day with no response, got myself a set of 19's off a ve 19x8 front and 19x9.5 rear and wanna find out how ill go with the rears.
    might do some running around 2day and try find out.
    Jan 2006
    Willall Racing
    wont be getting them fitted for a while mate, need tyres first, but wont buy them until i know they are going to fit.
    holdenhero is offline Car idiot
    1998 VT
    Jan 2009
    Maroubra
    Hey mate tell me how this goes... I keep breaking traction far too easily i need bigger tyres, tell me how this goes.
    I have 2 cars VZ sv8 6 litre and VU ute 5.7 litre
    Sep 2008
    Hi. I just fitted the VE rims on my car 9.5" x 19" with a 275 tire on it on the rear, yes you need to machine the center out but at the same time you will need to space the wheel out, I have found each car seems to be a little different as some need a 10mm spacer but I only had to use a 5mm spacer. I went a little further by lowering the car so the tire meets the level of the guard so I then got the guard rolled. If you go to a 8-10mm spacer you will need to change the wheel studs but in most cases 3-5mm resolves 75% of most vehicles.
    If you need further advice your welcomed to pm me
    Jan 2006
    Willall Racing
    Is that it? thats pretty easy.. i wonder why we dont see many of the fat rear VE wheels on cars.
    You got any good pics mate?
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Quote Originally Posted by SIG-054 View Post
    Because it's going to be hard to fit a 9.5" rear under the gaurd
    Selling FG G6E Turbo and buying a N/A Supra
    Jan 2006
    Willall Racing
    ive seen 10" under the guard of a VT-VZ, they were aftermarket rims though.
    And ive had 8.5" 20 tucked well up into the guard so ive figured it shouldnt be too hard to get another inch wider in there.
    Sep 2008
    I do and will post them up soon
    Jan 2006
    Willall Racing
    cheers mate.
    just found this out using an offset calculator comparing my std 18's to these 9.5" :
    The clearance from stut housing to the inside of the wheel will be 28mm LESS
    The outside edge of the wheel will EXTEND an extra 10mm
    So it shouldn't be too much of a hassle like 'Black as' has said
  15. #15
    Sep 2008
    Just remember its not the outside guard you have to worry about its the inner guard that you have the problem with, if you lower it then the outer guard becomes the problem and then you will have to get the guards rolled, I must say it looks as tuff as
  16. #16
    Jan 2006
    Willall Racing
    guards are rolled good and proper, and its slammed but not fussed whether i have to raise it or not.
    it should have enough room on the inner guard if spaced out a bit still awaiting your pics
  17. #17
    Sep 2008
    I'm at work so it will have to wait until I get home tonight "sorry"
  18. #18
    bpottz's Avatar
    bpottz is offline Whipped By SAPOL
    VT Berlina
    Aug 2008
    South Oz
    ill be keeping my eye on this thread, goodluck tom. it'll look tough as if it works out.. hopefully you dont have to raise her too much to make em fit cos its at an awesome ride height at the moment
    My VT Berlina [LIONLW] - Lowered, 18's, Leather
    http://forums.justcommodores.com.au/...tml#post863216
  19. #19
    Red 2011 FPV GS 5.0 S/C
    Jul 2005
    If you dont want them i'll buy them off you.... if the price is right.
  1. Fitting 19" rims to VT
    By MrJack in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-03-2008, 08:38 PM
  2. Fitting 19" Rims!!!!
    By AttaBoy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-01-2007, 08:01 PM
  3. fitting 6.5" into the REAR of a VS
    By Brycestro in forum Car Audio
    Last Post: 26-02-2006, 08:29 PM
  4. GENUINE HSV 17"RIMS + VT HSV REAR GARNISH MOULD
    By clubbie_50 in forum Parts And Other Items For Sale
    Last Post: 12-11-2005, 04:14 PM
  5. Tips on fitting 6.5" speakers to 6" pod
    By KILLERVS in forum Car Audio
    Last Post: 12-10-2005, 11:49 PM
