hi all,
im hoping someone can steer me in the right direction, my vt s supercharged has it airbag light on, i have replaced clock spring, also i was told from the person i purchased it off that the module with the key remotes were replaced prior to this and reset, then the light came back on , then i brought and replaced clock spring, also i disconnected the batt and fuses, but still comes on, any ideas ?????
After my carpets were steam cleaned, the light came on, I was told this often happens due to moisture in one of the connectors causing a bad connection somewhere around the consol. Check your connections.
how much did you pick the clockspring up for ??? im lookign for one atm as mines died.
___________________________________
Car: 07 VE SSV 6LTR L98 A6
Metalic Silver
Just go to holden and they will do a check and reset it. I've heard of people setting their airbag light on by putting a map book down the side of their seat.
That's right, it will stay on until Tech2 has been connected and the codes are read. They may charge you up to $80 for this. Mine was caused by a fault from the pretensioner, simply due to moisture after I washed the car.
There is no way around it.
