Results 1 to 4 of 4
Thread: Please help, VT V6 blocked vents, where to look next?
    May 2008
    Default Please help, VT V6 blocked vents, where to look next?
    99 VT V6, seems to be a block in the vent system somewhere. I have...taken out the dash and check the vac hoses(all good), dropped the fan and check all speeds and for debris stuck where ever my hand would fit(All good) checked vac hoses in engine (all good)...it seems that the air just doesnt flow out of the front vents, I can hear a loud muffled air sound near the passenger footwell/glovebox, like the air is just not getting out. The fan is weakest on the non-recir settings. could there be blockage to the air coming in the car somewhere....any advice on where to check next would be much appreciated!!!
    cheers
    kart_racer is offline Races karts
    VT Acclaim 5M
    May 2008
    Quote Originally Posted by jonnydico View Post
    cheers
    I have exactly the same issue in my VT. I took off the covers under the window wipers and the vent in there was half covered with leaf/plant matter so I cleaned that away. I think it's helped but I don't see how because the problem was still there with the air on re-cycle.
    I am also stumped at what would cause air to stop coming out of the vents all of a sudden... I can still hear the blower on all speeds.
    May 2008
    Default heater assembly?
    anyone think it could be something deep in the heater assembly? is there a common fault?
    cheers
    May 2008
    Default air intake flowing wrong way?
    just took off the cowl under the wipers and when the fan is on the air seems to be coming out the vent to the outside instead of being sucked into the car!!! anyone know why the heck this is happening or it is is normal? continuing to search for the problem in orig post....thanks
  1. Tyre valves blocked
    By HSVGTS E2 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-05-2008, 06:26 PM
  2. blocked nose
    By tmaybz in forum Jokes/Humour
    Last Post: 06-11-2007, 06:13 AM
  3. VT aircon slowly becomes blocked while driving
    By DJT_1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-10-2006, 01:01 PM
  4. blocked thermostat?
    By fantasy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-10-2005, 09:07 AM
  5. Blocked injectors?
    By s_pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-06-2005, 10:22 PM
