Results 1 to 4 of 4
Thread: Replacing smashed mirror
    VT Commodore S
    Mar 2009
    Default Replacing smashed mirror
    I stone has flicked up and smashed my right hand side mirror.
    Is it possible to replace the actual mirror? or do I have to buy the whole side mirror part?
    Thanks
    VY11 S pac commordore 6 cyl
    Jun 2009
    have th sme problm did youfind out how to remove the glass component, does it simply pop out if you pull from both sides?
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    To renew mirror glass:
    1 Adjust the mirror to the inner/uppermost position.
    2 Insert a flat bladed screwdriver into the opening and carefully disengage the clip
    retaining the mirror glass to the base plate.
    3 Move the glass in a circular motion to disengage the remaining clips and withdraw the glass from the plate.
    Installation is a reversal of the removal procedure with attention to the following points.
    1 Place the mirror to the base plate, ensuring that the vibration damper spring correctly
    engages the groove in the mirror housing.
    2 Carefully, but firmly press the mirror towards the base plate until the retaining clips are
    all engaged.
    3 Check the operation of the mirror.
    These instructions are from my Gregory's manual, I strongly recommend purchasing one for around $40. It will come in handy many times and save you money doing your own repairs.
    MY RIDE
    Vt S Pack Series 2
    Nov 2008
    if you live in melbourne, holmart sell them cheaper then $40 i think from memory there were around the $15 mark.
  1. Replacing the rear view mirror
    By rancid_b in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-12-2008, 04:55 PM
  2. smashed vs
    By traydog in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-12-2008, 02:48 PM
  3. new mirror glass on external electric mirror
    By atberry in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-01-2007, 08:01 AM
  4. Replacing Wing Mirror
    By daveb8 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 13-01-2007, 04:00 PM
  5. Right Side Mirror Needs Replacing..HELP!
    By lazza44 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2006, 12:07 AM
