Results 1 to 20 of 20
Thread: vt commodore
    vt calais
    Mar 2009
    Smile vt commodore
    hi guys wat would be causeing a wet spark plug in vt v6supercharged
    I have 2 cars VZ sv8 6 litre and VU ute 5.7 litre
    Sep 2008
    Sep 2008
    vt calais
    Mar 2009
    VT
    Apr 2005
    QLD
    vt calais
    Mar 2009
    vt calais
    Mar 2009
    every time i try to start it it cranks over but dosnt fire then take out back right hand side plug n it is wet
    VS l67 statesman
    Dec 2008
    VT
    Apr 2005
    QLD
    you might be able to tell whether it is fuel or coolant by smell and colour.
    could be a blown intake manifold or head gasket.
    vt calais
    Mar 2009
    VT
    Apr 2005
    QLD
    Quote Originally Posted by vtboy08 View Post
    its not the head gaskets theres no oil in the coolant?
    Doesn't matter as it doesn't always flow both ways.
    Best bet is to narrow down what it is on your plugs, then you can go from there.
    vt calais
    Mar 2009
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Its flooding.
    Check that your getting spark from the leads, if not then its a possible dud coil pack.
    If your gettin spark then it should be firing but wouldnt hurt to change your CAS
    VT
    Apr 2005
    QLD
    Quote Originally Posted by Ozzie View Post
    Its flooding.
    It's probably more the fact it isn't firing, if it is truly flooding, there could be a faulty injector.
    As ozzie said, pull the plug, put an earth on the body, put the lead on and wind the engine over to look for spark.
  15. #15
    vt calais
    Mar 2009
    VT
    Apr 2005
    QLD
    if it was only one cylinder out, it might still start. I'd say you have bigger issues.
  17. #17
    Sep 2008
  18. #18
    vt calais
    Mar 2009
    vt calais
    Mar 2009
    vt calais
    Mar 2009
    and thats after i take plug back out n clean it n put back in
  1. Commodore S ....Commodore SS... is there a difference..??
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-12-2009, 03:23 PM
  2. Do VN V6 Commodore injectors fit a VR V6 commodore
    By ozzybloke01 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-09-2007, 04:43 PM
  3. VN commodore exhaust into VR commodore
    By The Darkness in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-11-2006, 09:38 PM
