Results 1 to 5 of 5
Thread: ignition switch
    VT EX S1 3.8L
    Jan 2006
    Default ignition switch
    Hello all > I have just changed my ignition switch witch now works fine BUT now the steering lock does not engage after i have switched of the engine so when i remove the key no click and when i go to start up i have to jiggle the key to get it in the barrel and make it pop out! this problem was not ther until i changed the switch i cant see how i did something wrong instalin the switch can this be a computer fault or is the barrel gone to s h i t on the first start ?
    HELP ME and ill buy you a beer
    cheers
    VT EX S1 3.8L
    Jan 2006
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    It's not a computer fault but probably a barrel fault. It is common for pieces to break off inside the barrel and then cause it to jam, if the piece that breaks lands in the right spot. Maybe a piece had already broken in yours but wasn't a problem until you took it out and it moved. I would take the barrel out and look for broken pieces.
    MY RIDE
    VT EX S1 3.8L
    Jan 2006
    Thanks for the reply but i did not take the barrel out just changed the switch while the barrel stayed in
    VT EX S1 3.8L
    Jan 2006
    Quote Originally Posted by 6-PAC-ATTACK View Post
    ITS ALL GOOD NOW PLL i sprayed some graphite powder in the barrel whalla fixed
  1. Starter motor/ignition switch/neutral safety switch?
    By Drewie in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-02-2009, 08:19 PM
  2. replacing ignition switch ???
    By creamy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-07-2008, 03:39 PM
  3. VT Ignition Switch Removal
    By tyrefryer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-03-2008, 12:09 PM
  4. ignition switch
    By h0Ld3n`VN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-07-2006, 11:23 PM
  5. HELP! VK Ignition Switch
    By CommodoreChick in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-11-2005, 07:10 PM
