Results 1 to 4 of 4
Thread: new pad problems
    VT wagon
    Jan 2009
    Default new pad problems
    so... replaced all four corners with new pads, everything seems fine, bedded in ok, braking way better than expected
    now day 3, driving forwards and braking is fine, but when you stop, then reverse and brake, there is a clunking noise when your foot first hits the pedal, then after that, it seems ok again
    but the when you have done that, then drive forward and brake, same noise happens again, and it only ever does it once
    the brakes seem %100 all other times, so only when you change from forward to reverse and brake and vice versa
    so its like their being seated in the right spot for the direction your travelling, but that shouldnt really change if everytyhings in ok
    ive taken the wheels off and checked to see if everythings tight, and i havent done something wrong, all seems good, but its still doing it
    their kind of important so i dont want something to be majorly wrong
    any ideas?
    I have 2 cars VZ sv8 6 litre and VU ute 5.7 litre
    Sep 2008
    Swordsy's Avatar
    Swordsy is offline mmmm beer....
    VUII Maloo R8 - XJR1200 - XR450R
    Nov 2007
    Newi NSW
    sounds like the hand brake cable is too tight, either that you you didn't put the anti rattle springs in properly.
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Did you do the caliper bolts up tightly? If not the clunk you're hearing is the pad being moved around inside the caliper
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
  1. Signal Problems Aand LPG Problems
    By reyyan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2011, 08:33 AM
  2. Vz sv6 problems help!!!!!!!
    By allanssv6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-03-2009, 08:27 PM
  3. vn problems
    By h0Ld3n`VN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-06-2008, 09:30 AM
  4. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  5. Any Problems
    By andyman in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 12-05-2005, 11:16 PM
