Page 1 of 3 123 LastLast
Results 1 to 25 of 70
Thread: pods and loud???!?!?!
    stock VX executive.
    Mar 2009
    Exclamation pods and loud???!?!?!
    1.)i just fitted on a pod onto my v6 exec (Vx) and as people claim the induction sounds really good, i agree it sounds good but in my car i can only hear it wn its in park lol ... so any ideas wat myt make it louder?
    2.) i went to pitstop because i wanted to get a quote on a 'sports exhaust system' which i thot was a load of crap they expect me to pay 600buks which i personally think is a joke because i have heard you can get better sound for cheaper so how would i be able to do that.? and how much would it cost?
    cheers guis. reply asap lol cant waet i luv holdens
    sxc_sound's Avatar
    sxc_sound is offline getting Kustom
    VT Series 2 S pak
    May 2008
    Parkdale
    umm, you cant really make a pod suck louder... well without a turbo :P, also, i just fitted a sports exhaust myself, it cost me $208... and i got about 3 quote from shops around $280 - $350 fitted. so if you know how to di it yourself its cheap as. otherwize, dont pay a cent over $350 for a quality sports exhaust (cat back)
    2000 VX Calais 3.8L Supercharged
    Jul 2006
    you can make it sound louder by increasing the velocity of air passing through the pod entrance by using a smaller diameter pipe, but its useless really its just a restriction :P
    VE Calais V8 6 litre
    Feb 2009
    S.A. Sheidow park
    Mate, throw the pod out and put back the stock one, all the pod is doin is sucking in hot air from around the engine bay.
    At least the stock one was suckin cold/normal air from over the radiator.
    The only way a pod is good is if you get some pipe and run it straight down so it suck air from under the car.
    Just put back the normal air intake and buy a good K&N filter for the box. I think they cost 100bucks or so, but it better than a pod.
    sxc_sound- where about you from? looking at getting one for myself..
    nicko's Avatar
    nicko is offline Carbon Positive - DO IT!!
    75 cruiser ute
    Sep 2007
    sa
    Quote Originally Posted by sedmak View Post
    Correct. Although the standard holden filter is MORE than ok for a stocko 6.
    no longer a hoon by association - the commodore is gone
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    Feb 2009
    S.A. Sheidow park
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    lol spend a few months on here and u will see
    SIR LS1
    the two ton go kart
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    Pods are good in a DECENT front bar CAI set up, but just sitting in the engine bay (as already said) they are useless and do nothing for performance as all they do is suck in hot air.
    Better off with an OTR CAI with a panel filter. Pod's and sucking noise is just wank factor unless that's all you want.
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    mines modified to sit insde the original airbox with the lid sealed and the air coming from over the radiator. The sensor is modified also. It sits inside the pipe.
    My only restriction is the size of the pipe over the radiator.
    Cant hear my pod though.... anyone would think its standard.
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    ive got a pod in a heat proof sealed enclosure that sucks cold air behind the light it cost me a arm n leg having to order it from down south, b4 i got it i had the OTR with a K&N panel filter, once i put the pod enclosure on noticed way better preformance then the panel, i wud never just have a pod without an enclosure either so if u do either get it enclosed or get a panel man
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    You would have noticed your throttle would have been a bit tighter, they do sweet f/a for "performance", you just get slightly tighter throttle. Not a "performance" mod so to speak.
    You got some sort of CAI getting cold air into your sealed enclosure?
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    either way... he has a stock vx with a pod and wants it loud as he can get it.... i dont think performance is a issue in this case. keep the pod lol
    SIR LS1
    the two ton go kart
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    I do...
    The only real difference i find is better idle and slightly better throttle response.
    Biggest dowside was fuel economy without the sealed air box.
    The louder it is the worse the fuel economy is lol
    Since I chucked it in the standard box my fuel economy is normalish
  15. #15
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    If you want noise, go buy some PVC pipe from Bunnings or wherever with the twin 90MM ends on it, put 2 pods on it and it might give you some extra noise.
    I don't know much about making more induction noise, i never really got into that whole thing. I had a pod set up on my old VP, but i did a proper one that looked bog stock from the engine bay. Left the factory airbox in, took a fresh 90mm holesaw, cut through the bottom of the airbox and through the steel into the wheel arch (tyre removed of course just in case), took some 90mm PVC piping, slid it into the hole with an angle piece on it so the pod cleared the tyre, used plumbers waterproof silicone to seal everything up, bracketed and bolted the PVC pipe into place so it didn't move, added a second small piece of 90mm PVC pipe to the angled section so it pointed directy at one of the factory left and right side holes in my VP Senator front bar, and Sikaflexed a K&N pod onto the end.
    The reason for the extra piece of PVC pipe slotted into the end of the angled piece, was so i could pull the pipe out and wash and oil up the pod filter as they do need weekly cleaning when in a front bar set up.
    Worked bloody well. Didn't cost much either. I'll try and dig up some photos.
  16. #16
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by Cobez View Post
    its only getting cold air from behind the head lights atm but im thinking of putting my OTR back on and attaching piping to the end and running it directly into the enclosure
    oh and my pod on a cold start you can hear it in the car loud with windows up lol when warms up bit quiter but still can hear it sucking air in a fair bit
  17. #17
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    lol working at the wreckers a vs came in with the twin pod pvc mod. **** ive never laughed so hard
    SIR LS1
    the two ton go kart
  18. #18
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    lol i reakon it would look gay having 2 and i cant remeber where i heard it, but dont you lose power from having 2?
  19. #19
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
  20. #20
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    i didnt lol mines quicker then it was b4
  21. #21
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Quote Originally Posted by davecunno View Post
    Hahahaha, just because i suggested it, doesn't mean i like it hahaha . I would laugh too. But this guy seems to just want noise, so i guess you gotta do what you gotta do hahaha.
    Man it would look gay though. If you have the cash, bolt a blower on, then you will get some nice noise
  22. #22
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    lol the 0.3 kg weight reduction gives sick acceleration broo.....remove the washer bottle and air con compressor and it will do wheel stands !!!!! :O
    cover what if we modify a hair drier... rig it up to the induction pipe and hang twin pods off ... SICKKKKKKKKK
    SIR LS1
    the two ton go kart
  23. #23
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
  24. #24
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    how much ya reakon for a bolt on blower?
  25. #25
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    makita or ryobi ?
    SIR LS1
    the two ton go kart
  1. Loud pod
    By -Michael- in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-02-2009, 03:20 AM
  2. VT loud squel
    By Reubs in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-09-2008, 07:20 PM
  3. Really loud hum from Sub
    By kicker12 in forum Car Audio
    Last Post: 08-09-2008, 11:58 PM
  4. Vr V8 ute, 19's LOUD!!! YVR 05L
    By YVR05L in forum VR - VS
    Last Post: 25-02-2008, 02:33 PM
  5. vx ss LOUD
    By aygee in forum LSx Development and Modification
    Last Post: 07-01-2008, 05:11 PM
Tags for this Thread
