Results 1 to 18 of 18
Thread: Fuel-air guage problems
    BIG-EV's Avatar
    BIG-EV is offline Project VT (In Progress)
    2000 VTII Executive 3.8L Supercharged V6 Wagon
    Oct 2008
    Mango Hill QLD
    Default Fuel-air guage problems
    im having some issues with my fuel to air guage. its an auto meter 1 so i assume its good quality but after connecting it up to one of the O2 sesors im not getting a great reading, only when i plat the foot it shows me. any ideas it told me to tap into the O2 sensor wire which i chose the right 1 because its closer.
    its on a VT v6
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    it should swing back and forth when crusing and at idle it should sit still on a ratio and at wot it should relatively still on an af ratio.
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    BIG-EV's Avatar
    Oct 2008
    Mango Hill QLD
    so i attach it to the input at the ecu. could you show me how via a pic or some sort.
    Quote Originally Posted by davecunno View Post
    go from the ecu dude
    SMIT's Avatar
    SMIT is offline Donating Member
    VT C2R TURBO 5SP + CRUNCH VE SSV 6SP
    Aug 2005
    Mornington Peninsula, Victoria
    I am about to do the same install, it needs to goto the 02 sensor wire coming from the ecu, i just dont know what one, does anyone know?
    s1 vt
    Jul 2005
    to get an accurate reading you need a wideband sensor / gauge, the one you have just joins to the signal wire on the oxy sensors but be careful if they absorb the current/ reading from the sensor its going to mess with the ecu and run like shit.
    в∞ѕтεכ √&
    Jul 2008
    NZ
    yip ive they can pull upwards of 90mv's off the sensor signal wire sometimes depending on brand
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    OK, in the VT V6's the Powertrain control module has two Exhaust gas sensor connections.
    LH Bank:
    + - Violet [Location D15]
    - - Violet/Black [Location D16]
    RH Bank:
    + - Gray [Location D13]
    - - Gray/Black [Location D14]
    Location D is the top row of connections on the TOP PCM Connector. If you look at the connector with the clip facing towards the ground, all 4 will be in the top row on the far left!
    Please note, if an abnormal voltage drain is seen, it will start throwing errors through the ECU. If you want the diagram of that, available on request, i'm just a little busy atm to post it.
    SMIT's Avatar
    Aug 2005
    Quote Originally Posted by delcowizzid View Post
    Its an autometer ultralite, from memory which is wideband which is the better one yeah?
    One other thing came to me, i have a turbo on my car so would that mean each sensor would be reading different ratios? im no mechanic but is that correct? Does that mean i need 2 guages or just tap into the 02 sensor on turbo side?
    Nov 2008
    Tullamarine, Vic
    Since i have recieved PM's about images. Here they are below!
    In this image, you can see the connectors to the PCM. The one labelled YB193 is the one which has the oxy sensor wires.
    In this image, you can see a close up of the actual YB193 connector with colours and guides for which wires go where.
    And this is the image about the voltage details for what the PCM reacts to.
    в∞ѕтεכ √&
    Jul 2008
    NZ
    if its a wideband guage it wont work with a narrow band sensor
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    it wont matter where you tap into the wire, i've done mine in the engine bay and i've had not problems. my last set of o2 sensors werent giving me proper readings (i also had faults logged) when i changed them, the read outs are pritty much instant bar cold mornings takes a little to warm up. just remember to solder connections.
    SMIT's Avatar
    Aug 2005
    Ok im getting confused, is the sensor in the VT Wideband or Narrowband? i have a narrowband sensor i think.
    в∞ѕтεכ √&
    Jul 2008
    NZ
  15. #15
    SMIT's Avatar
    Aug 2005
    would it also be smart to put the connect it to the maifold with the turbo attached? lol or do i need 2?
  16. #16
    в∞ѕтεכ √&
    Jul 2008
    NZ
    where are both of the sensors at now one in the drivers manifold and one after the turbo the ecu will be wondering whats going on if they are
  17. #17
    SMIT's Avatar
    Aug 2005
    i never thought about that, could that be a reason why it could be idling ruff? im not 100% sure where they are atm, but i didnt change locations of the 02 sensors i had to lengthen one of the o2 sensor wires though for the manifold with the turbo on it? wait if i extended the wires then the resitance and VDR (voltage drop) would be differnet correct, rendering the ecu input signal slightly off?
  18. #18
    в∞ѕтεכ √&
    Jul 2008
    NZ
    nah you can extend the wires all good as long as they were soldered.if one side sensor is getting its signal from 3 cylinders on the drivers side but the other side is getting signal from all 6 cylinders in a conjoined manifold like the one with the turbo on it and the crossover going into it you will have issues thats for sure.allso if they are before the turbo they will get way to hot and die pretty quick.
  1. fuel guage problems
    By bendez in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-10-2008, 09:13 PM
  2. commodorevn fuel guage problems
    By commodorevn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-06-2006, 11:48 AM
  3. fuel guage problems
    By vlct400 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-05-2006, 11:12 AM
  4. vt belina - guage problems
    By vtbelina in forum Electrical Wiring / Questions
    Last Post: 04-12-2005, 08:50 PM
  5. Fuel Guage Problems
    By VXWAGMAN in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-06-2005, 04:29 PM
