Results 1 to 11 of 11
Thread: Supercharge "lag"
    Factory Blown VY S2 Calais
    Jun 2005
    Brisbane Bayside
    Default Supercharge "lag"
    I'm calling it lag because it behaves like a turbo - it just takes a while to kind of wind up from takeoff. It's most noticeable taking off from scratch, but it does "lag" when putting the boot in from cruise.
    It's my brother's car - and he's a pretty decent mechanic, but can't figure it out. Any tips on where to look would be appreciated.
    It a VT SII factory Charged, it has after market pipes but is otherwise stock. This "lag" behaviour is only recent.
    VS l67 statesman
    Dec 2008
    are you running the L67? if you are check the boost soleniond vacuum lines for cracks and the boost activator is working
    vx supercharged
    Feb 2009
    Jun 2005
    Brisbane Bayside
    What's involved there? Big or small job? He has taken the car to Holden - all they could say is "not showing any errors". Pretty lame.
    I'm assuming assessment of rotors would involve strip down?
    VY SII HBD Calais L67
    Dec 2006
    Quote Originally Posted by dannyn12 View Post
    ur rotors could be worn out they do wear out over time
    Not likely lol. There would be obvious symptoms if this were the case.
    VYII Calais L67
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    How bad is the actual lag? Like how many seconds?
    I would do what was already advised and check the boost control solenoid and the vac lines! If you took it to Holden and they said no fault then it wont be the bypass solenoid.
    Also check the air flow to the supercharger. To do this just stick your fingers in the air intake while the engine is running then pull the accelerator cord in the bonnet. you should feel the air rush in past your hand immediatly!
    2000 VX Calais 3.8L Supercharged
    Jul 2006
    perhaps its maybe not the engine? are you refering to the lag when giving it a boot from cruise? mine takes prolly half a second to react when cruisng at 80k's and booting it WOT, using power mode is pretty instant also...
    if your car is revving out but it takes a second for the car to actually start accelerating it might be a worn transmission/torque converter... somone else more knowledgeable might be able to enlighten you more on this^^
    try fitting a boost gauge so you can tell if the boost is coming on in a 'lag' sense
    Jun 2005
    Brisbane Bayside
    Thanks to all who have replied.
    Booting from cruise or from standstill shows poor response. It's not the transmission. Boost guage sounds worthwhile.
    '84 VH SLE
    Mar 2006
    having similar problems. However I do have a boost gauge fitted, and for an upgraded pulley, i can barely get it to 6psi....
    Solenoid and vac lines seem to be in tact. Any ideas guys?
    Jun 2005
    Brisbane Bayside
    VY Calais
    Jan 2010
    get your pulleys replaced, they might be slipping
    VY Calais, LS1, 19's, Lowered, VY2 Front bar.
  1. ""need help"" own a stocko 3800 vp and wanting to really give it some horsepower
    By boourns in forum V6 Development And Modification
    Last Post: 19-07-2008, 06:59 PM
  2. Starcorp Impul Wheels 18"x8.5" and 18"x9.5" Adelaide
    By vs_ss_matt in forum Parts And Other Items For Sale
    Last Post: 24-05-2008, 06:43 PM
  3. Is the warning "service engine oil" the same as "check oil" ?
    By morris in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-12-2006, 04:36 PM
  4. The "gears" and "power" in an auto
    By nath_120 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-07-2006, 08:59 PM
