Hey own a 1998 Commodore Vt s and was just wondering with the VTs already coming with OTR induction, whether it is worth getting an induction kit from say SS or something like that? or is there some way you can improve the already existing one?
Thanks
waste of time buying as ss induction kit... infact they reduce the amount of air force... hence they are nicknamed commonly ss REDUCTION kits... do a search up on the forum thers somethign called a "2 hole mod" that heaps of people have done.. ther is a how to section it should be in there... cheap, relativley easy if u have the knowledge and hand skills yet much more effective
cheers
If All Else Fails, Then You're Probably Driving A Ford
2 hole mod is for vy/vz dude, diff shape airbox thats why its not in vt/vx sextion :P
dont mean to sound like a prick,
Mark
theres a how to on here somewhere about cutting up the stock opening to increase air flow, I've done it to my car but havent noticed anything except the sound of the air rushing in has gotten a fair bit louder.
this is it, except I've also taken a chunk out the bottom of it too since the pic.
i made my own induction, cost $10 takes no time, works better then them ss things
pvc pipe, blue glue, cut and paste
Thanks for your help guys, just another question, is ther much diff in air temps from say behind the headlights or somewhere lower down like dimetime has made?
Thamks
im not sure about behind the headlight but i just took my car for a thrash for an hour and a half down the freeway and my new pipe and my air box are icey cold?
better to have air intake higher on the car so you dont suck water in really wet weather. not sure about temp diff. couldnt be much
had shocking rain the other day and was panicing about the new pipe, got home and checked it all was fine! hot air rises so thats way i went for one down the bottem, pipe doesnt sit that far down,
this is the black plastic lip under the bumper
use alloy and it will cool the air more.
weld fins inside with a nice curve and it cools more
i do as the voices tell me
Pics of these fins? Im attempting this in a few days time.
