Results 1 to 6 of 6
Thread: Coolant Pellets?
    VT Berlina
    Mar 2009
    Default Coolant Pellets?
    Did my mechanic put in the coolant pellets after flushing and adding new coolant? Something i did not know to ask. He assured me that all is fine when I asked if there was anything I needed to do. I will have to ask him about that. What problems can occur if the pellets are not added?
    Bob.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I've only ever added them once in over 20 years of owning commodores and can't say I've ever noticed any problems.
    MY RIDE
    vt berlina series 1
    Sep 2008
    VX 'S' S1
    Apr 2005
    South East,Victoria
    I was told they are crushed walnut shells and are used to keep the crap off of the impeller in the water pump not sure if it is true or not.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    The pellets are used to plug up microscopic holes in the alloy engine casting. If you aren't losing coolant then it's probably not an issue for you.
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    Use the pellets, Holden still sell them, they are used in new and old cars. THey also seal leaks around the waterpump, intake and head gaskets. For a normal leak they clot the area and swell/dry on the air side, around the hot areas, heads etc, it bakes and chars hard to seal minor leaks..... same as bars leak, but the pellets can be better. I use them with every change. Many manufacturers use similar products to stop the nuisance leaks during the warranty periods.
  1. Cooling system pellets
    By Lloyd1986 in forum General
    Last Post: 15-02-2007, 12:30 PM
  2. pellets
    By ab56452001 in forum General
    Last Post: 19-01-2006, 06:31 PM
  3. How MUCH coolant ???
    By comtim in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-10-2005, 03:41 PM
  4. V6 Coolant Pellets
    By tricky160 in forum General
    Last Post: 20-08-2005, 06:34 AM
  5. VX V6 Radiator pellets
    By Spyder in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-06-2005, 03:30 AM
