Results 1 to 12 of 12
Thread: Rear main seal Gen 3
    VT SS
    Mar 2009
    Default Rear main seal Gen 3
    I have an oil leak, and its dripping from the joint between bellhousing and engine. The sump has been weeping aswell, but not bad. Is it a big job to change the seal? Any advice would be appreciated.
    Flano
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    H1GHROLLR's Avatar
    H1GHROLLR is offline CHEMICALLY SUPERCHARGED
    VX CLUBSPORT R8 LS1
    Feb 2009
    ROCKINGHAM,PERTH
    pain in the ass job thats what it is , its an easy job but one you will hate
    VT SS
    Mar 2009
    Yeah I figured a pain in the ass! Do I do the sump gasket while the gearbox is out? Will it drop down far enough?
    H1GHROLLR's Avatar
    VX CLUBSPORT R8 LS1
    Feb 2009
    ROCKINGHAM,PERTH
    Boonz's Avatar
    Jul 2005
    do the rear main with the box out, put the box back in and do the sump gasket by dropping the k frame down a bit and supporting the motor from the top
    H1GHROLLR's Avatar
    VX CLUBSPORT R8 LS1
    Feb 2009
    ROCKINGHAM,PERTH
    Quote Originally Posted by Peanuts Inc. View Post
    sounds like a good way to do it mate
    VT SS
    Mar 2009
    Ok cool I have seen the rear main and plate for $120 on ebay, is this a good price?
    H1GHROLLR's Avatar
    VX CLUBSPORT R8 LS1
    Feb 2009
    ROCKINGHAM,PERTH
    VT SS
    Mar 2009
    Will putting the front wheels up on ramps be high enough to get the box out? Also how far does the K frame have to be dropped to get the sump out, and can this be done on the ramps aswell or on stands?
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    Try some HM oil like Shell helix Plus High Mileage or Maxlife from Valvoline. Even try some Auto-RX additive. Seals leak for 2 reasons, they are dirty-shrunken from poor oil and changes, or they are damaged. THe oils and additives can cure it from the 1st one, cleaning around the seal so it seats properly, and also using seal swellers to bring them back to original. It its the second one, damaged, it must be replaced, you just never know, but cheaper and easier to use a oil to see if it stops it. If you use the oil and additive, and it starts to leak a lil more, you definately know it was cause the seal was dirty, it will eventually stop or slow.
    SICK SS is offline 7L 427ci BABY
    427 ci vu ss a4 ve ssv a6
    Jan 2007
    central queensland
    Quote Originally Posted by Flano View Post
    no you will need car stands.its a big job geting the box out on your back. Took me 3 days lol and heaps of piss but i reckon i could do it in a day now that ive done it before.
    RAPTOR CHARGED 330RWKW VU SS UTE IF IT DOSNT BLOW IT SUCKS
  1. 304 rear main seal??
    By fatty1 in forum V8 Development and Modification
    Last Post: 18-10-2008, 10:08 PM
  2. Rear Main oil seal AGAIN
    By LisnM8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-07-2008, 05:48 PM
  3. vn s1 rear main seal
    By shyvn6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-06-2006, 07:28 PM
  4. Rear main seal
    By mouce in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-05-2006, 03:45 AM
  5. Rear Main Seal
    By rebel in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-01-2004, 11:29 PM
