Results 1 to 10 of 10
Thread: Replacing Tail Light and Drivers Side Door Lock and Latch
    VT Executive S1
    Aug 2005
    Exclamation Replacing Tail Light and Drivers Side Door Lock and Latch
    My cars getting a road worthy soon and I need to replace a rear tail light and lock and latch on the drivers side door. 98 Exc Vt. Any help ?
    98 VT Berlina
    Nov 2008
    Western Suburbs, Victoria
    I have two Series 1 Tail lights if you want to buy them off me. Already packed and ready to post. Chasing $80 plus postage for both.
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Help with what? Installation, sourcing??
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    VT Executive S1
    Aug 2005
    I changed the tail light thanks anyway.
    How do I take out the latch on the door ? Where do I begin ?
    Then installation.
    Thanks in adavance
    Static89's Avatar
    Static89 is offline I Am Ironman.
    VT Berlina S1
    Jul 2008
    Sherwood QLD
    the latch? as in the handle or the prt that clicks into the body?>
    ParkwayDrv: the worst thing for a hangover would be vkc
    VT Executive S1
    Aug 2005
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    you have to take the door skin off and remove the handle from the inside. Depending how bad it is, you might be able to modify it to get it working. If not, you'll be able to pick one up second hand cheap enough and fit it.
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
    VT Executive S1
    Aug 2005
    VT 5.0 auto
    Nov 2008
    Quote Originally Posted by Zedlen View Post
    Thanks, how hard is it to take the door skin off ?
    easy
    you will see screws right round the outter edge of your trim (i say trim not skin)
    start by unscrewing those,
    then you need to pop out the little orange lug on your door lock/button,
    use a pocket knife or something similar, & carefully pop it off
    remove the button then you will see a screw in the plastic section behind where the button sits
    *could be a screw around the inner handle, cant remember*
    thats all there is to it trim should come off
    VT Executive S1
    Aug 2005
    Quote Originally Posted by mofo sixx View Post
    easy
    Thanks sixx,
    Does anyone know how to change handle or have any links to a site with instructions, I don't want to mess with central locking without knowing what I'm doing ?
    Or if not replace it, how it can be fixed ? its only the lever itself that wont open the door.
  1. [WA] Fs: Vt white drivers side door with window,door skin &mirror - $60 - perth
    By Timzo in forum Parts And Other Items For Sale
    Last Post: 12-01-2009, 07:59 PM
  2. door lock button - drivers side
    By barny in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2009, 06:12 PM
  3. VS Drivers Door Lock
    By PsYko in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-03-2006, 10:02 PM
  4. does a vt berlina drivers door lock have a light
    By justbad4you in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-10-2005, 05:32 PM
  5. Drivers Door Lock
    By S Pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-07-2005, 09:19 PM
