Results 1 to 8 of 8
Thread: Central Locking problem
    VT Commodore
    Mar 2009
    Default Central Locking problem (Solved)
    A difficult one. I cant open the drivers door. You can hear the solenoid clicking but the mechanism does not operate. I cant remove the trim because I cant open the door. Anyone any thoughts on how i open the door. The interior handle and knob dont do anything.
    The missus is getting sick of clambering over from the passengers side.
    SweetWagon's Avatar
    SweetWagon is online now booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by sdrambo View Post
    Sounds like it has been deadlocked, Have you tried unlocking it using the key?
    VT Commodore
    Mar 2009
    Quote Originally Posted by vn6pwr View Post
    The key does not work either, some rod or other appears to have fallen off.
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    does the locking knob go up and down? or is it seized?
    Im not sure how you can remove the door trim with the door closed, but you can remove the handle, get access to the rods?
    VT Commodore
    Mar 2009
    I'll try removing the handle and see what is going on.
    VT Commodore
    Mar 2009
    The locking knob was seized. I brute forced it up and was able to unlock the door. The red button had fallen apart and jammed the button in the down position.
    VT 5.0 auto
    Nov 2008
    lift drivers door handle (outside) , on the left under the handle you will notice a small slot
    if you stick a thin (but lengthy) screw driver in that slot,
    this will activate the central locking
    hth
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Quote Originally Posted by mofo sixx View Post
    hth
    Judging by this...
    He already got it unlocked...
  1. VY SS Central Locking Problem
    By #1zero in forum VY Holden Commodore (2002 - 2004)
    Last Post: 02-06-2008, 09:06 PM
  2. Central Locking Problem
    By Chirpstr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-12-2007, 08:33 PM
  3. VT2 Central Locking Problem
    By Stretcher Bearer in forum Electrical Wiring / Questions
    Last Post: 04-03-2007, 11:19 PM
  4. (Another) VR Central Locking Problem
    By Riff88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2007, 12:51 AM
  5. Central Locking Problem
    By pegga in forum Electrical Wiring / Questions
    Last Post: 25-12-2005, 10:07 PM
