Results 1 to 7 of 7
Thread: Coolant doing a hoodini...
    -Michael-'s Avatar
    -Michael- is offline Ooh Yeah.
    VT S Pack
    Oct 2008
    Default Coolant doing a hoodini...
    Hey guys
    Got a problem with my VT. I managed to lose 7 litres of coolant within 5 or so days and then its probably now a litre every day and i dunno where its all going!
    No leaks on my driveway, no dripping anywhere, i'm stumped!
    social's Avatar
    social is offline Ute Finatic
    MY06 6.0L VZ Thunder(na naa na naa..)
    Nov 2008
    South Aus
    itttssss MMMAAAGGGIIICCC-AAAAHHH....
    Onto the proper answers...
    Possibly cracked head? Thats first check, look under oil lid, if its milky, ur in trouble.
    Secondly, pressure test with a pump, if theres a leak, you'll see it squirting out one of the hoses, it may be a leak over the engine it self / leaking onto exhaust making it evaporate fast enough for you not to see it happen
    Also, possibly leaking radiator?
    Quote Originally Posted by Shooter03 View Post
    Washed it and now the wife's gonna take it out and get it dirty.
    Quote Originally Posted by QldKev View Post
    You are talking about the car?
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    I would be guessing it's getting into the oil. Loosing so much and it not appearing anywhere suggests that. To leak it onto your echaust you'd see a fair bit of steam and it would be noticeable. In the engine the coolant would just get burnt when it gets up into the combustion chamber and pushed out.
    VP's used to have a problem where their heat exchanger could leak and the carpet inside the car would get wet, but i'm fairly sure holden fixed that from the VR's onwards. If not, definatly should have been in by the VT's!
    vt berlina series 1
    Sep 2008
    check the drivers side radiator tank it may not leak out till youve driven for a bit , itll have a white residue all over the place
    -Michael-'s Avatar
    VT S Pack
    Oct 2008
    Well, went and had a look and no coolant on the dipstick or on the oil cap.
    faulty radiator cap?
    -Michael-'s Avatar
    VT S Pack
    Oct 2008
    vt berlina series 1
    Sep 2008
    ahhhh that old favourite, $20 and its fixed
LinkBacks (?)
  1. 23-03-2009, 08:34 AM
  1. What coolant do you use
    By glowworm in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-11-2007, 06:29 AM
  2. coolant
    By Holden V8 SS Ute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-11-2007, 09:22 PM
  3. Coolant In VX GEN 3
    By 1stGEN68 in forum General
    Last Post: 03-04-2006, 12:43 PM
  4. coolant
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-03-2006, 02:18 PM
  5. How much coolant?
    By paddyj in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-03-2006, 01:57 PM
