Results 1 to 24 of 24
Thread: electric window conversion parts
    callum_88's Avatar
    callum_88 is offline Donating Member
    VT Exec 5 spd/ VZ SS 6 spd 6ltr
    Nov 2008
    Salisbury Downs, SA
    Default electric window conversion parts
    ive got the regulators and the wiring inside the door, i know i need the front and rear switches, what else do i need
    im guessing its the four looms connecting to the main switch or module/relay
    am i correct? im unsure
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    You will need a MID level BCM and the loom for the main switch block if it is not already in place. Being an Executive it probably won't be.
    MY RIDE
    callum_88's Avatar
    Nov 2008
    Salisbury Downs, SA
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    I'm 99.9% sure that in my VX the wiring is there in the center console. Unscrew the two screws either side of your 12v cigarette lighter power plug and pull the console that surrounds the gearbox up and out and look for a cable with a plug. roundabouts where the power window switches are.
    I would assume all the cars would come with the wiring and BCM ready for power windows to save time on production lines. If you have the wiring, your BCM should be fine too. You will need all 4 new door trims though because you will have holes where the winders were and you'll need holes in the back trims for the switches. Any door skins will do, you can swap the fabric insert from your existing trims onto it so it matches. Just make sure the skin covering is the same shade of black/grey
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by callum_88 View Post
    oh ive heard you dont need one
    :S
    You might already have a MID level BCM, but most execs have a LO level which doesn't allow for power windows. This is according to my Gregory's.
    MY RIDE
    vx executive - Trumph TR6 - Toyota surf
    Jul 2008
    Tauranga NZ
    I recently converted my VX exe to power windows the master plug was already in the center consul it had the low level BCM this would not allow the drivers window to operate - solution there are two wires that come off the r/f rocker switch they alternate between + & - to drive the window regulator up or down.I traced them to the drivers footwell where I cut them, joined and ran new wires directly to the regulator the only thing is the r/f window wont go down automatically like a factory one you have to hold the switch till its down - no issue realy ! I wouldnt even bother buying the door looms a bit of work threading new wires and your done.
    callum_88's Avatar
    Nov 2008
    Salisbury Downs, SA
    oh great cheers
    so would i need some wires that connect to the plug in the centre console that go to the rear and front regulators?
    where do i locate this rocker switch?
    so then i just need the switches and trims and ill be good?
    Jul 2008
    Tauranga NZ
    Hey Callum if you can use a volt meter I can help you, if not its best left to a professional cheers
    VE SV6
    Apr 2006
    Alice Springs NT
    simple question does your car have ABS brakes?
    if yes then under the the gear lever towards the back you should have a white rectangle plug that isnt pluged into anything that is the plug for the centre console switches for power windows. if that is there the rest of the wiring will be there just plug in the door looms and regulators and switches then go to holden and get a MID level BCM installed then its all done.
    now if you dont have ABS brakes thats a bit harder you would probably be better off getting a pro to install the rest of the wiring from scratch for you
    for some reason ABS and power windows came together as a option from factory so if you have ABS the wiring will be there for power windows except for the doors if you dont have ABS none of the wiring will be there.
    now for the BCM
    even if the wiring is there for the power windows doesnt mean that you would have a MID BCM installed from factory.
    the only difference between the LOW and MID BCM is Power windows and electric aerial being an exec and if you dont have a electric aerial from factory and because you dont already have power windows you would only have a LOW BCM
    callum_88's Avatar
    Nov 2008
    Salisbury Downs, SA
    i can use a multimeter, i almost have cert 3 in electrotechnology
    im not sure if i have abs, but i have seen a white rectangle plug not plugged into anything, but it was a bit higher than the centre console just in front of the gearstick on the left, i may look a little lower when i get a bit more time as i just had a quick look.
    can i use that method that topzone was talkin about? instead of getting a new bcm?
    cheers for all ur input everyone, as i have no idea with this power window stuff
    callum_88's Avatar
    Nov 2008
    Salisbury Downs, SA
    ohkay well i dont have abs, so does that mean i definately dont have the wiring harness for power windows, because i saw a plug in the wiring thats not plugged into anything, if its not for the switches any other ideas what its for?
    Mick1988's Avatar
    Apr 2008
    Take a picture of it and we'll soon be able to tell you
    callum_88's Avatar
    Nov 2008
    Salisbury Downs, SA
    okay took apart my console and there seems to be a plug with nothing going to it, around the mark of where the switches should be.. so im hoping that its for that, let me know if you saw the same thing
    cheers
    also that last picture is a picture of this other plug doing nothing, what would that be for?
    Attached Thumbnails Attached Thumbnails electric window conversion parts-img_1156.jpg   electric window conversion parts-img_1155.jpg   electric window conversion parts-img_1160.jpg   electric window conversion parts-img_1157.jpg
    VE SV6
    Apr 2006
    Alice Springs NT
    thats not the plug for the power windows, if it was there the wiring would come out from that hole in the carpet in the first pic. i am sorry but you dont have the wiring for power windows mate
    the plug in the last pic that comes out the side of your console is for the mobile phone hands free kit.
    if you want power windows mate i would honestly sugest getting a auto elec to install it for you, trust me i had the same problem you have now with my old VT and i ended up getting a whole wiring loom out of another vt with power windows and stripped out just the wiring for the windows but it was a headache to do even for me and i have had a few years expierence with wiring up other cars
  15. #15
    callum_88's Avatar
    Nov 2008
    Salisbury Downs, SA
    Oh you definately sure about that? does the plug look obviously different to what this plug is for? If so what is this plug actually for then?
  16. #16
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The plug for the window switches is about 2 inches wide and has about 8 or 10 wires.
    MY RIDE
  17. #17
    VE SV6
    Apr 2006
    Alice Springs NT
    i know this switch is out of a VY but the plug that goes into it is the same as the VT-VX
    and is the same plug for the factory stereo in a VN-VP
  18. #18
    callum_88's Avatar
    Nov 2008
    Salisbury Downs, SA
    oh cheers for your help.
    ive rang up a few auto electricians, some dont do it, some do it, the two people ive rang that do it said they were looking at about 250-300ish but he wasnt sure he could do it, and another person said that lookin for about 550ish! i really think thats ridiculous does anybody know someone that can do it or at least tell me what i should do, because i am fairyl cluey on electrical as ive got a certificate in electrotechnology, i just dont want to f*** around with wires.
  19. #19
    SMIT's Avatar
    SMIT is offline Donating Member
    VT C2R TURBO 5SP + CRUNCH VE SSV 6SP
    Aug 2005
    Mornington Peninsula, Victoria
    ok ive never done this but i think all you will need is:
    MID PCM (not BCM??? dont know.)
    wiring in all doors,
    main wiring loom,
    regs in all doors
    main switch block
    rear switches
    You know enough to do it yourself, just might be a bit time consuming.
  20. #20
    VE SV6
    Apr 2006
    Alice Springs NT
    for the body wiribg you could buy a body wiring loom out of a wreck with power windows and just strip the power window wiring out, or if you can get the power window wiring out of a VQ wich has a seperate wiring loom to the main loom and modify the plugs to fit your car (i have done this before and it does work).
  21. #21
    callum_88's Avatar
    Nov 2008
    Salisbury Downs, SA
    ah kay, cheers guys
    so if i got a body loom, is it pretty hard to work out which is the power window wires?
    i may have to trace them and see on the wires i have now and the wires i have and compare the wires with the new loom?
  22. #22
    vy sv8
    Nov 2010
    sydney
    Quote Originally Posted by hitman1979 View Post
    now for the BCM
    just because u have abs doesnt mean u have the window loom mine has not got the loom
    In respect to Jason Richards a great racer and an even better man, taken away too early may u rest in peace mate u will always be remembered.......... what a legend.
  23. #23
    vx wagon exec
    Jun 2011
    Nsw
    Got to know instead of making a new thread if I have abs and an electric aerial does this mean I already have the mid level bcm
    Edit: btw its a 2001 vx executive
  24. #24
    vy sv8
    Nov 2010
    sydney
    Not really I have a vy sv8 with no cruise or power windows but has abs and electric ariel and I still have a low bcm which is not compatible for power windows I also don't have the power window harness some are different but so I say have a look for it first before doing anything else
  1. Electric window conversion
    By cruzn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2009, 07:45 AM
  2. VT 1997 - Electric Window Conversion
    By ShaneS in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-06-2008, 05:18 PM
  3. VS Electric Window Conversion
    By Mallee308 in forum Electrical Wiring / Questions
    Last Post: 06-05-2007, 08:42 PM
  4. vn-vs electric window conversion kit!
    By wizza in forum Parts And Other Items For Sale
    Last Post: 29-05-2006, 10:15 PM
  5. WTB - electric window parts
    By stocky in forum Swap / Wanted to Buy / Trade
    Last Post: 11-01-2006, 12:25 PM
