Results 1 to 13 of 13
Thread: Holding Revs
    vt s s1
    Mar 2009
    Default Holding Revs
    Hey guys i have a VT manual and ever since the other day when i took the throttle body off and cleaned it it seems to hold the revs for a second when going to change gears. It is prodomentally between 2 and 3 thousand revs and most noticable when going from 3rd to 4th for some reason.. It takes about a second i found cos il be going in say second let go of the gas and press in the clutch and hold it. If the revs are just below 2000 they will actually slowly rise and if aroubnd 2000 just hold for a second and then go down like normal.. Also when changing from higher revs ie over 3500 it just drops like usual.. Ive had it sitting in nuetral and hold revs at 2000 then let off throttle and it drops str8 away which is why im baffled.
    Can anyone help?? Thanks
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Had a similar issue when i swapped my TB to a bigger one...
    Did you take the TPS sensor out when you where cleaning the TB?
    The reason its holding that rpm and rising like you said is noramlly because the IAC valve is doing funny things... and the iAC valve does funny things primarily when the TPS isn't installed correctly or faulty.
    If you did take the TPS out, I will need to find a diagram of a TB to explain what you should check for... always a pain in the arse to explain.
    vt s s1
    Mar 2009
    Talked to my boss about it today and he said 2moro wel reset the IAC im pretty sue so thus must be it. I did take out the sensor but was sure i put it back properly, guess not, anyway il let you know 2moro what it was. Thanks Jest
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    vt s s1
    Mar 2009
    Yesterday reset the IAC and nothing but today while sevicing the car took off the throttle body off again and this time took of the IAC and gave it a goon clean out. It still happens but it wont actually rise in revs but boss said that this is normal and said it was the idler motor if i remember correctly. All good now
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    So all good? Sweet... good to hear.
    FYI,
    The thing i was talking about was this little plastic sleeve that slides onto the flat prong from the TPS into the throttlebody butterfly axle (Worst description ever right there).
    ANyway, its like maybe 7mm by 7mm.. and if you don't put it on it throws the TPS out like what you said.
    It took me pulling apart my TB 3 times before i noticed the thing was missing.. lol
    Couldn't find a diagram to show on it...
    Anyway, Good to hear all sorted.
    vt s s1
    Mar 2009
    Yea its all good thanks mate
    Luckily i didnt take 3 times to take it off.... only 2 :S lol
    I think i know what your talking bout the connection on the bonnet side of the TB..
    Thanks for your help dude
    SuperSixty6's Avatar
    SuperSixty6 is offline Alto Rullo
    Landcruiser TD
    Dec 2008
    Brisbane.
    Having the same issue,
    I removed the piping from the Throttle Body, And took out the air box and MAF to clean it a little – Im also in the process of fabricating an alloy air box.
    I pulled apart the MAF and got the alloy ends and polished them up, Nothing else was done to the MAF. The throttle body was untouched during the process to my knowledge.
    However now, I will tap the accelerator and it will hold at 1200-1500rpm for around 4 seconds.
    Any help?
    vt s s1
    Mar 2009
    maybe just take the throttle body off and clean it and dont forget the IAC aswell.
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    I would be looking at the piping you disconnected from the tb.
    Check for clogs and make sure the pipes are in the right spot and properly connected.
    Good luck.
    2000 VX Calais 3.8L Supercharged
    Jul 2006
    on the TPS there is a little plastic tab that goes over the drive part on the sensor, make sure you dont lose it :P
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    ^^^ Already mentioned that in post 6... though you described it alot better than me... lol
    Landcruiser TD
    Dec 2008
    Brisbane.
    Hi Guys,
    I never had the TB of when I did the MAF. I removed the TB today, Cleaned it and the sensor. Still holding the revs, Not as much but defiantly noticeable. Any ideas? Not to sure what this black plastic piece is though?
  1. another dumb Question (304 holding back)
    By twinturbo5l in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-11-2008, 04:54 PM
  2. Removing Studs Holding Pwr Steering Pump, V8
    By deserthead in forum General
    Last Post: 28-02-2008, 06:23 PM
  3. VT v6 5spd engine holding revs when i clutch it
    By xx1600xx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-01-2008, 09:02 AM
  4. VL Automatic holding 1st when cold
    By rx3 madman in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-04-2006, 09:18 AM
  5. trans holding gear
    By flip1906 in forum V6 Development And Modification
    Last Post: 21-12-2005, 06:17 PM
