Results 1 to 3 of 3
Thread: VX V6 Thermostat
    2002 VX Executive S2 ex:Police
    Mar 2009
    Default VX V6 Thermostat
    I have to install a VX V6 thermostat tomorrow, I had a look at super cheap auto they have them plus the grey gasket, in a thread I read here there was mention of a thermostat O ring, do these use a sealing O ring or just the grey gasket when installing the thermostat any thoughts or tips would be appreciated
    Regards Chris
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    VX uses a gasket, about $2. Use sealant on it as well. DO yourself a favour and get teh Tridon High Flow Thermostat. Ask them for the Part No, as some places dont know it. You get it with the standard temp 190+, but with the higher flow gives you the benefits of a cooler 180 thermo without messing up the computer and engine fans.... MOst part places can order it for you.
    Mar 2008
    heres a link to the tridon website , they work well the hi flow thermos , open the link below and put in your vehicle details, i think you will find the part number for the hi flow thermostat is
    TT2003-195 Thermostat (High Flow) 08/2001 08/2002 High flow thermostats allow approximately 30% more coolant flow than STD thermostats.
    TTG46 Thermostat Gasket Paper style gasket. Sealing compound should be used.
    just double check if and when ordering
    Tridon | Part Finder
  1. Which way does the thermostat go? + highflow thermostat?
    By thek in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-02-2009, 11:11 AM
  2. VN 5.0 thermostat
    By Noy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-02-2009, 02:33 PM
  3. VT V6 thermostat
    By savage1987 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-05-2008, 02:07 PM
  4. thermostat
    By homer simpson in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-10-2007, 06:31 PM
  5. thermostat
    By pr0n in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-02-2007, 06:58 AM
