Results 1 to 8 of 8
Thread: I need advice on yet another radiator flush...
    VT Berlina
    Mar 2009
    Default I need advice on yet another radiator flush...
    Hi, i recently bought a second hand VT Berlina and had it serviced.
    Among other long term problems with it, it also needed a radiator flush which i just got done today due to the water being very brown.
    It had 3 flushes today and is still brown and needs another flush.
    at $110 a pop and being unemployed i'm having trouble justifying this being done again and then finding out theres worse damage which will cost me more money again.
    I wish to drive to melbourne in may, this is my upmost priority.. what will happen if i dont flush the radiator again? Will it get me to melbourne? What are the long term ramifications?
    thanks
    Aaron.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Are you flushing the engine and heater core as well or only the radiator?
    MY RIDE
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    theres a good product im trying to think of the name it neutralises rust in the cooling system and can turn rusty water clean before you drain the system cant for the life of me remember the name though
    VB SL/E
    Dec 2008
    Haydz's Avatar
    Haydz is offline Fasten your seatbelts
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    the system is easy to flush yourself. if you are unsure how. spend 40 dollars and buy a gregorys manual.
    it will save you lots of money.
    good luck mate.
    VT Berlina
    Mar 2009
    Thanx everyone for your help.
    No i didnt pay $330, i paid $110 for 2 flushes, but they must have felt kind and did it a third time for me, but they recommend doing it again in another couple weeks.
    This is exactly what they did:
    "Coolant Flush Service
    Examine all belts and hoses, pressure test radiator and cap. Drain old coolant, examine old colant for contamination etc. Flush radiator and block, refill with new coolant as specified. Bleed system including heater, normalise engine. Test for leaks."
    "Water was in very poor condition even after 3 flushes. Recommend another coolant flush in appros 1 week"
    My brother knows how to flush the radiator.. so i'm thinking of just risking it, waiting a month, driving to melbourne then hopefully if i make it then we can do it there.
    I'm just worried about it breaking down on the way or something.
    By the way, its not overheating or getting hot or anything.
    Thanks
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    your car wont break down because it needs coolant. as long as it has water and your not flogging the absolute shit out of it. get some cleaner stuff you add to your water.
    then drop it when you get there and put in some fresh coolant
    vt berlina series 1
    Sep 2008
    what a rip off , to clean a radiator out you have to remove it from the car and remove the inlet tank then push metal cleaning rodes down the tubes to clean all the crap out of the tubes, you then high pressure blast the radiator by putting a pressure hose in the outlet pipe then blasting all the crud out of the tubes/radiator inlet tank is then put back on and radiator is pressure tested , that is the only way to remove buil up in the radiator ,
  1. Radiator Flush
    By brad_m_is in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-11-2007, 11:18 AM
  2. radiator flush
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-01-2007, 12:08 AM
  3. Radiator Flush
    By paullmichelle in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-11-2005, 08:22 PM
  4. how to flush my radiator
    By GeorgeB in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-07-2005, 04:52 PM
  5. Radiator Flush
    By MySV6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-11-2004, 02:17 PM
