Results 1 to 5 of 5
Thread: Temp warning alarm
    locoman is offline locoman
    04 WK Statesman
    Sep 2006
    murraylands SA
    Default Temp warning alarm
    The other day after travelling 70 Km the overheat alarm sounded, and the temp gauge went from normal to maximum and then went down to normal again and the alarm stopped, all in about 5 seconds.
    I stopped and checked coolant etc. and found all normal, the radiator was NOT even hot at the top, and in fact the Radiator cap was cool.
    A friend of mine has a VX and says his has done it twice now, so can I assume it is a small glitch in the computer.
    My car is a 200 VT series 2 Berlina, with 116,000Km on the clock.
    Any help much appreciated.
    VY SII HBD Calais L67
    Dec 2006
    Sep 2004
    can also be a lose hose which has the slightest leak but its happend to me to and nothing was wrong i pulled over cjecked water coolent etc but was all good so i rekon sometimes can be a fault in computer or the thermostat like was said!
    2002 VX Executive S2 ex:Police
    Mar 2009
    Hello
    After spending about $1600 about a month back repairing the carnage caused by a blown radiator, including cracked head, never take a overheat warning for granted, my 2002 vx would show hot once in a blue moon, then come straight back down again when coolant was short, just because radiator is full doesnt allways mean thats all well, badly worn water pump blades can cause overheat while still plenty of coolant, do your self a favour and get it looked at and fully checked out, if all checks out fine, cool but neglecting a warning can cost you alot more if there is a problem.
    Regards Chris
    04 WK Statesman
    Sep 2006
    murraylands SA
    Cheers Guys and Gals, its booked in on Monday for a service and checkup.
  1. Q's regarding Coolant Temp & Intake air temp sensor
    By Steven M in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-02-2009, 05:08 PM
  2. gauges oil temp and engine temp
    By vzon20s in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-11-2008, 05:31 PM
  3. Electric oil temp and water temp gauges
    By FRESH_VR in forum General
    Last Post: 02-09-2008, 04:27 PM
  4. What temp should my VP run at?
    By richie_cky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-08-2006, 12:33 PM
  5. Cannot find the answer - Fuel/temp gauges, warning lights
    By stocky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-11-2005, 07:40 PM
