Results 1 to 5 of 5
Thread: 99 berlina radiator fan won't turn off
    99 V6 berlina
    Mar 2009
    Default 99 berlina radiator fan won't turn off
    Any help, the radiaotr fan in my 99 berlina won't turn off when car is off. have to disconnect batttery every time. have seen previous posts about amplifier under plenum cover. have removed plenum cover and there is nothing under there but the wiper motor.
    thanks
    Scott
    WAGON MAN's Avatar
    WAGON MAN is offline Gas Sleeper
    VX S2 Berlina Wagon with Phreddied bits.
    Jun 2006
    North Coast , NSW
    99 V6 berlina
    Mar 2009
    thanks wagonman. You would happen to knowwhere i could get a daigram of for the fuse box for my 99 berlina as it doesn't have one in the lid.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by skippyd View Post
    You could probably get the sticker that goes there from Holden.
    MY RIDE
    1999 vt ss 5.7l series 2
    Jan 2009
    hi there my vt had the fan staying on just recently and i checked the relays and the low speed fan relay was hot compared to the others. the have a tendoncy to weld them selves together on the inside if they are cheap relays, keeping the compontent effected powered up consantly. i recomened using hella relays. hope this helps.
    p.s. check relays when u pull up some where after fan has been running for a while.
    mick
  1. VE Full Map/ Turn by Turn SatNav question
    By Boeing737 in forum VE Holden Commodore (2006 - ?)
    Last Post: 10-05-2007, 10:53 AM
  2. Berlina VY II stereo, how do i turn off auto tone adjustment?
    By Acehoilo in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-05-2007, 01:57 PM
  3. Radiator hose on VT Berlina
    By VtBerlina_3800 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-03-2006, 10:53 PM
  4. help! vt radiator fans don't turn off
    By oneade in forum Electrical Wiring / Questions
    Last Post: 18-11-2005, 09:15 PM
  5. Problem with amp turn on/turn off
    By don80 in forum Car Audio
    Last Post: 05-06-2005, 08:06 PM
