Results 1 to 7 of 7
Thread: Sounds like a wrx!
    VX Executive
    Feb 2008
    Default Sounds like a wrx!
    just yesterday as i was cruising on the highway otw to work, the engine started to develop a "baap..baap..baap..baap" noise. There was some vibrations at the wheel and when i came to a traffic light stop, the car would go "baap..baap..baap" as if it was like a subaru with those cannons. Acceleration was slow and the vibration got worse. At first i thought it was the tires but when i reached the garage the engine was shaking 'abnormally' and can still hear that "baap..baap..baap.." noise.
    I thought it might have something to do with the coils or the plug leads or the spark plugs. but all these check out, nothing damaged or broken. the engine mounts were installed last year. Dont have the tools to open up further into the engine so will be taking it to the shop. I took a peek inside the throttle body, clean...the idler motor was good and the cables opening the throttle body was clean, no sign of rust or sticking. I sure hope its something like a transmission mounting bush or something involving the suspension, but even when stationer the engine still shakes. The wheel are balanced with 8month old tires.
    I'm sure it cant be the tires since tyhe engine make this noise standing still. this morning starting up the car was a shocker as i could feel the firewall being hit with some constant thuds. Like a dwarf with a hammer. I'm worried to drive it along the highway, if something breaks loose or the vibrations get worse.
    Checked the pulleys and belts. none of them were seized.
    Will let u know wat seems to be the problem. has anyone had this problem?
    Jun 2005
    is it an exhaust noise? take your rocker covers off and check that none of the rockers are loose
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Has the exhaust broken? One of the flanges on the manifolds may have come loose.
    Visit my Facebook page
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    sounds like you have a miss somewhere, be best to take to mechanic to check over.
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    My bimmer sounded like that when I had a sticking lifter and rocker arm...
    So +1 on what stocky said.
    Jun 2005
    Quote Originally Posted by Jesterarts View Post
    yeah pretty much what happened to me. i also thought "hmm, sounds like a wrx". one of my rocker bolts had loosened a bit, and from memory, caused a valve to get stuck open. noise sounded like an exhaust leak at first, then got louder until the engine died.
    VX Executive
    Feb 2008
    Solved!!!
    Actually it was combination of items that were causing the sounds and the vibrations.
    VIBRATIONS...
    When i first checked on the engine i had put back the spark plug cables. When i took them off again all 4 cables had cracks in them. Previously i had checked the engine mounts and the transmission mounts, bushings so i was sure it wasnt them going faulty. the wheels were also balanced. but upon startup the engine was vibrating abnormally inside the engine bay. The silicone (silly?) cone dust boots at the engine side of the spark plugs cables had given up the fight to heat. All 4 had cracks and the one leading to cylinder number three was exposed. Upon trying to reinstall the cable the connector snapped. I changed back to the original BOSCH plug cables since they have the meatl heat shields over the plug cables and the cylinders fired up fine.
    However the ignition pack on the left side of the car paid the price for the voltage geeting fedback to it. The car engine still wasnt running smoothly. Changing the ignition pack to a new one made the engine run soooo quietly...and the power was back on again.
    Took it for a test drive and remembered that this was how the car felt like when it was new. To be very sure i checked the injector plugs, no signs of corrosion or cracks. The fuel pump is still new, no leaks in any hoses in the engine bay. Cost me some coin to fix the problem but once i took the time to eliminate every single possible cause of the fault, i understood the car better.
    SOUNDS...
    While i had the car jacked up, one of the exhaust pipes had a tiny crack near the CAT. Putting my hand around it when the engine was running i could feels exhaust gases spewing through it. I dont want to ghetto fix-it so by this week i will have the crack to be patched up by a welder.
    At least the vibrations have gone totally, but as much as i like the 'baap...baap...baap" wrx sound, i'd prefer a silent ride
  1. Help, My VT sounds like a lawnmower
    By U2Bono in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-04-2007, 08:39 PM
  2. VP sounds to REV HIGH
    By ir8prim8 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-07-2006, 09:37 PM
  3. car engine sounds please
    By Coxy_vs in forum The Pub
    Last Post: 27-05-2006, 02:47 PM
  4. Which supercharger SOUNDS the best??
    By savage1987 in forum V6 Development And Modification
    Last Post: 02-04-2006, 11:27 PM
  5. Sounds Better... Looks Better...
    By jazza21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-03-2004, 12:41 PM
