i have a stock eurovox cd player,can i put another one in the same with the only difference being it has a cassette player as well or do i need different wiring?thanks
If you're talking about a CD player that came out of the factory in a VT/VX commodore it should just slide right in.
VX2 Executive Sedan - 3.8L Auto (for now)VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
If you buy one second hand, which you probably will because you would have to be nuts to pay a fortune for a new one from Holden, make sure you get the PIN code with it. Usually plenty on ebay cheap.
MY RIDE
im also in adelaide. i have a 98 VT executive with a cassette player. if you want to swap, i'd be more than happy!!! so long as its plug and play.
As long as it is the Eurovox one you will be able to just connect it and you will be sweet, but as accentstencil says, make sure you get the PIN for it or you will be stuffed
