Results 1 to 12 of 12
Thread: Security Coded VX CD Player
    chrism182's Avatar
    chrism182 is offline VX S Pack
    VX S Pack M5
    Sep 2008
    Victoria, Australia
    Default Security Coded VX CD Player
    Hi,
    I'm going to be getting a new head unit soon, and I noticed that my security coded light flashes when I haven't turned the key. Will this get in the way of removing the stock head unit? If so, how do you reset the security code/enter the security code cause I have no clue what it is.
    Thanks,
    Chris.
    eziautoparts.com.au
    Your total auto parts store on the web!
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    there should be a card in your owners manual with the security code and key codes ect on it.
    If you cant find that card then you will need to pay holden for it.
    You will need to give that code to the next person who gets the unit.
    How to enter the code is also in the owners manual.
    chrism182's Avatar
    VX S Pack M5
    Sep 2008
    Victoria, Australia
    Hmm.. I also don't have the owners manual.. This is gonna be a problem.
    eziautoparts.com.au
    2002 VX Executive S2 ex:Police
    Mar 2009
    Hi Chrism
    Yes whenever disconnecting the battery over a couple of minutes, the cd player/radio will flash the word code and wont operate until the 4 digit number has been inserted.
    My VX was second hand when I bought it, it was owned by queensland police prior to me, they had the 4 digit code written inside the front cover of the owners manual, it wasnt labeled as such but first time I replaced the battery I was presented with code and when looking through the owners manual came across the 4 digit number tried it and it worked
    heres what the owners manual says
    Radio P.I.N. (Personal Identification Number)
    Your PIN. must be entered if the battery is disconnected. The P.I.N. is shown on the
    security card that was originally in the glovebox of the new car. Please keep the card in
    a safe but accessible place (not in your car), as this safety feature is provided as a theft
    deterrent.
    To enter the P.l.N.:
    • turn ignition to accessories and turn radio on (“1” or “CdE 1” appears),
    • press the radio buttons in your P.I.N. order,
    • the radio will shortly begin to play.
    If an incorrect P.I.N. is entered the number “2” or “CdE 2” appears on the display.
    Following three incorrect P.l.N.s the display shows” - - - “, and the radio must remain
    connected to power for approx. one hour before the correct P.I.N. can be entered.
    Therefore, if your car repair requires battery disconnection you may wish to provide the
    servicing dealer with your PIN.
    If the P.I.N. number is lost, contact your Holden Dealer. He will require proof of
    ownership and the Vehicle Identification Number shown on the inside front cover of this
    handbook. There may be a nominal charge for this service.
    Regards Chris
    chrism182's Avatar
    VX S Pack M5
    Sep 2008
    Victoria, Australia
    Thing is I don't have the manual. It didn't come with the car when I bought it.
    eziautoparts.com.au
    '02 VX Berlina
    Apr 2007
    Adelaide, SA
    that light wont affect the installation of an aftermarket head unit. just take out the old an in with the new.
    and you might want to find out the security code before you take it out, in case you decide to sell it afterwards or return it when you sell the car.
    i came across this problem with my VX after disconnecting the battery for some reason. i called a holden dealer and they asked i come in with the car and proof of ownership ie. rego paper, and they were asking $25 for the code. luckily, i still had the previous owners number and called him. he still had the little security info card and told me the number over the phone. then i picked up the card some time later.
    chrism182's Avatar
    VX S Pack M5
    Sep 2008
    Victoria, Australia
    So I am able to remove the stock headunit with the security code set?
    eziautoparts.com.au
    '02 VX Berlina
    Apr 2007
    Adelaide, SA
    yes you can remove stereo with code set. there will always be a security code on that head unit. thats its security feature.
    VXII Berlina 5.7L / VW Golf GTi
    Mar 2009
    South-west Sydney NSW
    Quote Originally Posted by chrism182 View Post
    Yeah dude you are. The security code light is only flashing as a deterrant to would-be theives letting them know they will not be able to use it in another vehicle without the code.
    So basically, if you are going to install an aftermarket headunit and throw your old one away, you will NOT need that code. The only reason you would need it was if you wanted to sell it to someone for them to put in their car. You can get it but Holden will charge you a fortune to do it, so wouldn't be worth it i'd reckon.
    Hope that helps
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    I thought that in the engineers mode you could see the default pin for the original stereo?
    I saw somewhere the Pn XXXX that shows up is the pin code for the original stereo. In my car it's not but my stereo could have been changed. Worth a try.
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    Quote Originally Posted by Mick1988 View Post
    the radio pin is stored in the BCM, dealers can retrieve it with a tech2, provided it has been updated when if the unit was changed it will be correct.
    the display in the cluster extended menu you mention is the part number of the cluster
    goofball_9996 is offline aint got shit to do
    vx s pack
    Feb 2009
    mandurah
    you can take the seriel number of the stero to holden and thay should be able to help you
    or if the stero is stantard to the car take the vin number to holden and again thay will tell you with no problems
  1. colour coded skirts??
    By VT II 2000 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-11-2008, 08:51 PM
  2. colour coded grille
    By Timzo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-01-2006, 07:46 PM
  3. Replies: 5
    Last Post: 17-10-2004, 02:18 PM
  4. Is it security coded?
    By Kim in forum Car Audio
    Last Post: 23-04-2004, 04:30 PM
  5. The Security Coded Cassette Player
    By Gold_VR_Berlina in forum Electrical Wiring / Questions
    Last Post: 25-01-2004, 10:25 PM
