I don't think the servicing stamps have much value. If it was my car I would be performing the whole 40,000km service - oil, oil filter, fuel filter, brake fluid, clutch fluid (if manual), radiator coolant, spark plugs etc. You will need a special tool disconnect the quick release fittings on the fuel filter. Available from Repco for around $20. You may have to modify it slightly by cutting about 5mm off the end to get it to fit properly on the quick release fitting. Sent me a PM if you want more information.
